 '40 Ford coupe
Go to page : 1, 2, 3, 4  Next
PostSubject: '40 Ford coupe   Thu 03 Sep 2015, 10:10 pm
An almost complete new kit that was in my care package.
I dug out from my display case of my favorites, a 2006 build that I wasn't completely happy about the chop. I  was (and still am) reluctant to eliminate the 'B' pillar and make a hard top. Just seems to be a cop out way to chop a top.  OK, at the time, I chose to just close in the rear quarter windows. Have never liked how it looked.
Anyway, I'm thinking to chop this one, leaving the 'B' pillars in. I also think I'll do a "Bonneville chop",  slanting the windshield for more visibility. I haven't decided yet if I'll section it some. And, MAY go skirted tail dragger.
Unlike my first one that had a 1 piece floor/frame, This kit has more pieces. Had a little fiddling to do with those X members.
And trying to get a small warp straightened.
Didn't have a good dropped axle, so I salvaged a front end out of a pickup truck, and removing the 40 front cross member, I'm fitting this in it's place.
I may have to do something with that frame X member after all that work getting it straight, because I found another Viper engine in the salvage.
PostSubject: Re: '40 Ford coupe   Thu 03 Sep 2015, 11:22 pm
Hi Mr G,
I'm in...
Andy... popcorn
PostSubject: Re: '40 Ford coupe   Fri 04 Sep 2015, 12:03 am
Me too.
PostSubject: Re: '40 Ford coupe   Fri 04 Sep 2015, 12:44 am
PostSubject: Re: '40 Ford coupe   Fri 04 Sep 2015, 12:46 am
Great stuff Clay. popcorn
PostSubject: Re: '40 Ford coupe   Fri 04 Sep 2015, 8:46 pm
Very nice work.
PostSubject: Re: '40 Ford coupe   Fri 04 Sep 2015, 10:06 pm
Well, so much for their fancy schmancy cross over.
PostSubject: Re: '40 Ford coupe   Fri 04 Sep 2015, 10:10 pm
Well if it don't work .... have it away and onwards and upwards.
PostSubject: Re: '40 Ford coupe   Tue 08 Sep 2015, 5:17 pm
OK, I am backing down on this baby.
Sectioning may cause more problems with hood clearance that I  don't want to fight with. I already have to do some serious firewall work. And because it's looking so good, I may abandon the top chop. Lazy ol' man still has some work to do getting the tail down.
PostSubject: Re: '40 Ford coupe   Tue 08 Sep 2015, 6:52 pm
I like the unchopped look of it.
PostSubject: Re: '40 Ford coupe   Tue 08 Sep 2015, 9:25 pm
BIG BIG engine!  No wonder it will take more than a shoehorn to fit it in.  A modest chop might look good and offer "B" pillar options (vert. or slant).
PostSubject: Re: '40 Ford coupe   Thu 10 Sep 2015, 10:03 am
She's up on 'er wheels with the engine installed.
I have never shaved the tops of the tires, before, to get clearance to drop a body, But fudging on out of sight stuff is not against my morals.
I have modified the Viper intakes and have them tucked behind the radiator.
Moderation is not really my thing either. When I chop a top, I leave no doubt that it has been chopped. I usually lay out my chop lines with 1/4 inch tape. So, I usually have a lot of wiggle room. Showing marvelous restraint, I'm using 1/16 inch tape to lay out the lines on this coupe.
With my chopped pieces laying around, it doesn't seem as easy as it used to to get them all aligned.
I keep seeing this , that I have lying over on the other table with the salvage stuff. Not exactly a confidence builder.
PostSubject: Re: '40 Ford coupe   Thu 10 Sep 2015, 6:08 pm
LOL. No not a very pretty sight at all. 1/16 inch is a 1 1/2 inch chop in scale.
PostSubject: Re: '40 Ford coupe   Thu 10 Sep 2015, 9:22 pm
Got the 'Road Kill' out to see if it was worth the effort compared to a stock height roof.
Not too bad.
Then I had to set them next to the more extreme chop.
PostSubject: Re: '40 Ford coupe   Fri 11 Sep 2015, 6:33 pm
I would say perfect. Good choice, Clay.
PostSubject: Re: '40 Ford coupe   Sun 13 Sep 2015, 12:12 am
Took a pretty good hunk out of the firewall.
PostSubject: Re: '40 Ford coupe   Sun 13 Sep 2015, 6:11 pm
You want a big motor you gotta have a big engine bay.
PostSubject: Re: '40 Ford coupe   Thu 17 Sep 2015, 6:51 pm
Got to set out in the studio today give my legs a rest! Two days on a ladder destroyed them for anything else !
Working on the body work, and cut down the inner door panels.
PostSubject: Re: '40 Ford coupe   Thu 17 Sep 2015, 10:09 pm
It's coming along great Clay.
PostSubject: Re: '40 Ford coupe   Thu 17 Sep 2015, 11:38 pm
Up a ladder?!  You are an inspiration to us all.  I like the "modest" chop.  Severe chops to me only make sense for Bonneville machines.  I would get claustrophobic in some of the cars I've seen.  Glad you're safely on the ground with the snakes and gators!
PostSubject: Re: '40 Ford coupe   Fri 18 Sep 2015, 6:06 pm
Looking good Clay. The new roof on the green house looks good also. LOL
PostSubject: Re: '40 Ford coupe   Fri 18 Sep 2015, 6:22 pm
Thanks.
Yeah, thanks for that too. 3 days later, I'm still feelin it !!!
PostSubject: Re: '40 Ford coupe   Tue 22 Sep 2015, 12:32 am
Doin some final body sanding. Nosed the hood and shaved the trim. Then decided I ought to shave the belt moldings on the body.
PostSubject: Re: '40 Ford coupe   Tue 22 Sep 2015, 12:59 am
looking good Clay. Maybe you should shave the drip rail too?
PostSubject: Re: '40 Ford coupe   Tue 22 Sep 2015, 2:20 am
Either way works, though I lean slightly to the 'leave in on' camp. It breaks up a large area of 'metal'
I'll shut up now & leave Clay to work his magic.
'40 Ford coupe
» AMT John Milner 32 Ford Coupe
» 1932 Ford Coupe
» 1932 Ford Full Fendered Hot Rod
» 1936 Ford Coupe
