 Community Build #9 Military
Go to page : 1, 2, 3, 4  Next
PostSubject: Community Build #9 Military    Wed 01 Jul 2015, 4:04 am
Here you go guys, any land based military subject.
Enjoy !!
PostSubject: Re: Community Build #9 Military    Wed 01 Jul 2015, 5:37 am
so heres my entry for the GB
had this in the stash for a very very long time, i can remember buying it on ebay when i got back into modelmaking so it must have been 2007 or 2008, often thought of doing it but chickened out to do something else but its time has come lol
its certainly the largest AFV kit ive attempted
done my old trick of making a hole and gluing in a nut,,,,i have a threaded rod which then screws thro the bottom of the hull giving me a 'handle'
ive also bonded in a few large heavy nuts. this will add some mass to the whole thing. ive done it before and it helps to make it sit on the tracks a bit better, and makes it feel a bit more substansial if you pick it up
and heres the real deal......plan is to make a simple sand covered base for it all some how
seems they started out in a green colour, often overpainted in a sandy colour.....ive seen pics of some extremely weathered ones where the sand paint is worn away but thats way beyond my abilities, so its going to be a sandy one lol
PostSubject: Re: Community Build #9 Military    Wed 01 Jul 2015, 10:38 am
Like Paul, I have been itching to start this one.
This is what I will be building.....
....towing this....
.... probably on a simple base.
I saw this one at a recent model show and just new right off I had to build it. Paul's photo, not mine:
I would have likied to do it in North Africa colours but although the Long Tom was used there, the tractor was not. So it's going to represent the combo as used in Korea.
Will probably get started tomorrow.
PostSubject: Re: Community Build #9 Military    Wed 01 Jul 2015, 1:05 pm
Good luck guys, I'll join in shortly.
PostSubject: Re: Community Build #9 Military    Wed 01 Jul 2015, 6:12 pm
Some good subjects there. I am watching all the way.  popcorn
PostSubject: Re: Community Build #9 Military    Thu 02 Jul 2015, 12:26 pm
I'm ready.
PostSubject: Re: Community Build #9 Military    Thu 02 Jul 2015, 7:20 pm
Found this ... WW1 - military (and i think we said it was anything military?)
I know it's another Airfix and i'm gonna probably moan about fit and flash but it looks a real cool kit !!!
PostSubject: Re: Community Build #9 Military    Fri 03 Jul 2015, 1:46 pm
the bus is a classic and ive been looking for one for a while, so will look forward to seeing yours go together
i hope to make some progress on my M60 later......just been signed off work on the sick for a week so need to occupy my time lol
PostSubject: Re: Community Build #9 Military    Fri 03 Jul 2015, 3:50 pm
Hobbycraft Paul .... bout 20 quid
PostSubject: Re: Community Build #9 Military    Fri 03 Jul 2015, 4:06 pm
im a skinflint....never pay the going price lol lol
PostSubject: Re: Community Build #9 Military    Fri 03 Jul 2015, 4:51 pm
So I've noticed!!
PostSubject: Re: Community Build #9 Military    Fri 03 Jul 2015, 5:17 pm
PostSubject: Re: Community Build #9 Military    Sat 04 Jul 2015, 9:00 pm
this seems to be one of those kits with a zillion parts in the box.......it seems ive been sticking bits together for ages and not got that much to show for it
i think it will be one of those that suddenly all comes together
PostSubject: Re: Community Build #9 Military    Sat 04 Jul 2015, 10:07 pm
PostSubject: Re: Community Build #9 Military    Sat 04 Jul 2015, 10:24 pm
Zbuckster wrote:
a penguin?????? lol
PostSubject: Re: Community Build #9 Military    Sat 04 Jul 2015, 11:21 pm
That ,little guy is doing "The Happy Dance" after seeing your work.
PostSubject: Re: Community Build #9 Military    Mon 06 Jul 2015, 9:55 pm
got most of the reactive armour added today
the kit came with two figures but one is complete rubbish and has been binned......which just leaves Moshe the legless tank commander lol
looking forward to laying down some paint in a few days
PostSubject: Re: Community Build #9 Military    Thu 09 Jul 2015, 1:52 pm
Well this Airfix kit doesn't disappoint .... i mean that in a negative way
Every bit i've cut off the sprue has been like this
This is the outside (on show) side complet with sinkholes, embossed number and extrusion marks ....
And this is the inside (hidden) which is completely perfect....
GO FIGURE !!!!
Lots of filling and sanding to be done!!
PostSubject: Re: Community Build #9 Military    Thu 09 Jul 2015, 6:05 pm
Man-O-Man, that makes no sense at all.
PostSubject: Re: Community Build #9 Military    Thu 09 Jul 2015, 6:28 pm
The reactive armour looks good Paul.
Man that's hard to believe Colin.
PostSubject: Re: Community Build #9 Military    Fri 10 Jul 2015, 1:39 pm
After filing and sanding relevant bits i've arrived here.
There may not be too much of a problem as a lot of the holes/raised areas will be covered with the external wooden planking i intend to add. (definitely not using the optional cardboard stuff provided by the manufacturer ... it's a bit tacky)
Both main body bits built up
And together to check fit
Gave the interior a bit of detailing although the only way you'll see it is iff you look through the slot windows that will be left or through the back access door
I intend to paint it up as an airfield version and not as an "in the field" version so will be airfield grey instead of dark green.
PostSubject: Re: Community Build #9 Military    Fri 10 Jul 2015, 4:52 pm
its basically together, all the greeblies are attached, the bustle was an absolute pain!not as neat as i would have liked but its the best its going to be. it will get filled with cans and boxes and stuff anyway
next will be some paint, and im not sure what im going to do, need to go and do some more research....................or looking at pics of tanks on the net as swmbo calls it lol
PostSubject: Re: Community Build #9 Military    Fri 10 Jul 2015, 6:08 pm
Looks good Paul.....
I have top and bottom together and painted
Got the top seats painted in a wood grain (ish) and the metal supports attached
Now the real bus had the lower deck windows and the top deck side panel openings boarded and canvassed off like this....
I'm going to make it so a few of the lower window boards are hinged and dropped down ... that way you'll still be able to see the detail inside
Better than the airfix cardboard efforts they give you
And i REALLY want to get another and do this to it.
PostSubject: Re: Community Build #9 Military    Fri 10 Jul 2015, 11:13 pm
carrier pigeon......the 1918 equivalent to text messaging lol
PostSubject: Re: Community Build #9 Military    Sat 11 Jul 2015, 12:04 am
Brilliant series .... the last episode is quite poignant.
Had a few brushes with Robinson when I did some photographic cataloguing for a time team dig, 2006 in boswortn if memory serves... nice bloke.
