 200mm WWI British infantry.
PostSubject: Re: 200mm WWI British infantry.   Fri 21 Aug 2015, 6:26 pm
Still looking good, and I am still learning a ton.
PostSubject: Re: 200mm WWI British infantry.   Fri 21 Aug 2015, 6:31 pm
Cheers Buck, Ive put a little mud on the shovel now with MIG mud.
PostSubject: Re: 200mm WWI British infantry.   Fri 21 Aug 2015, 6:40 pm
That is great work Gary. Well done. Learning a lot here for when I get back to Hanz!!
PostSubject: Re: 200mm WWI British infantry.   Fri 21 Aug 2015, 6:43 pm
Thanks AL, been a bit slow on it but trying to make an effort.
PostSubject: Re: 200mm WWI British infantry.   Sat 22 Aug 2015, 5:36 pm
Started work on the backpack with MA light brown base, MA Sand(ivory) highlight and MA dark yellow shadow.
PostSubject: Re: 200mm WWI British infantry.   Sat 22 Aug 2015, 10:12 pm
Bloomin Eck, love the muddy shovel, looks very authentic...Keep the posts coming chap
PostSubject: Re: 200mm WWI British infantry.   Sun 23 Aug 2015, 8:50 am
Cheers Ash, will do.
PostSubject: Re: 200mm WWI British infantry.   Sun 23 Aug 2015, 6:43 pm
That Mud on the shovel is awesome. Man-O-Man it looks good. Great tutorial Well written and very,very informative.
PostSubject: Re: 200mm WWI British infantry.   Sun 23 Aug 2015, 6:51 pm
Thanks Buck, MIG dry european mud straight from the jar. Applied a tiny bit at a time with an old brush until it looked OK. Didn't want it too thick as Im sure they weren't daft enough to lug a shovel with thick mud on around.
PostSubject: Re: 200mm WWI British infantry.   Mon 31 Aug 2015, 3:22 pm
More work on the backpack, when properly blended Ill put in the brass fittings and try using pens to draw the seams and outlines instead of using a brush. Ive done this before and as long as the colour is right it works well. I have a set of Pigma Micron pens and will try a black brown and burnt umber.
PostSubject: Re: 200mm WWI British infantry.   Mon 31 Aug 2015, 6:14 pm
Looks good fella, liking the paint display you have in the back ground too
PostSubject: Re: 200mm WWI British infantry.   Mon 31 Aug 2015, 6:54 pm
Still holding my attention, So well written and I am learning a ton and a half.
PostSubject: Re: 200mm WWI British infantry.   Mon 31 Aug 2015, 9:35 pm
Ash, thank you, nail polish display stands off eBay.
Buck, cheers, Im glad your finding it of interest.
PostSubject: Re: 200mm WWI British infantry.   Sat 12 Sep 2015, 2:28 pm
Bit more work, blocked in the socks and boots. Socks blocked in with the three uniform colours and boots with Nato black model air. Im not going to town on these as he'll be quite heavily spattered with mud when mounted on the base so I will detail when this is done if its needed.
Cleaned up the arms and begun to attach and fill. I'm going to attach the arms then paint, however the hands are folded to the rifle and because he is holding the gun very close to his body I'll paint this before fixing it.
PostSubject: Re: 200mm WWI British infantry.   Sat 12 Sep 2015, 5:51 pm
Nice work, Gary. One of the best Tutorials ever.
PostSubject: Re: 200mm WWI British infantry.   Sat 12 Sep 2015, 6:09 pm
Cheers Buck, temporarily on hold LOL. see quick tips.
G.
PostSubject: Re: 200mm WWI British infantry.   Fri 09 Oct 2015, 8:12 am
Apologies for the lack of posts. Have been busy with little to show for it. Haven't posted the cutting, sanding and filling as I know we've all seen enough of that LOL. Also during this process I lost all the shoulder tile letters which Ive now replaced (lesson learned). Anyhow FINALLY,  both arms on now and painted in the three uniform colours with blending and glaze medium. Needs a coat of flat now.
Started blocking in the rifle and hands.
rifle base coat in Vallejo Model Air (MA) flat brown.
strap and bayonet handle in MA sand
hands in Model Colour flat flesh.
Ive bought some of the new Vallejo metallic colour paints and will give them a try on the gun. If they're as good as they look Im going to re-touch the brass fittings etc on the figure.
PostSubject: Re: 200mm WWI British infantry.   Thu 15 Oct 2015, 3:05 pm
More work on the rifle blending the wood tones using MA dark brown and burnt umber, shades and highlights done on the hands with black red and light flesh respectively. (and many mixed tones between). Glaze medium used throughout.
Vallejo metal colours, Steel, Gun metal and aluminium used for the guns metal elements and the bayonet blade.
I have re-touched the buttons and buckles with metal colour gold, which I think looks great as polished brass. Thats pretty much it for the figure apart from some touches when he's on the base, especially on his legs and boots which will be muddy and I intend to include some still and splashing water effects also.
If there is no objection I would like to continue with the base work as part of this thread as I will be scratch building a trench bottom 'duckboard', and muddy ground. This will also allow me to 'fully' finish the model and show any final touches I may do upon completion.
PostSubject: Re: 200mm WWI British infantry.   Thu 15 Oct 2015, 4:57 pm
I would like to see the base done. No problem at all. Looking forward to it.
PostSubject: Re: 200mm WWI British infantry.   Thu 15 Oct 2015, 5:49 pm
Cheers ZB.
PostSubject: Re: 200mm WWI British infantry.   Fri 16 Oct 2015, 1:20 am
Hi Gary,
He is absolutely S T U N N I N G Sir, and as Mr Z said, I too would love to see the base come together as it will be a complete how to then...
PostSubject: Re: 200mm WWI British infantry.   Fri 16 Oct 2015, 5:07 pm
Thank you so much Andy. Ill be posting the base progress soon.
PostSubject: Re: 200mm WWI British infantry.   Sat 17 Oct 2015, 3:12 pm
Decided on a Yew base and used blue tac to position the plaque, tunic button, shoulder tile and regimental badge. Then fixed with CA.
Cut 10mm styrofoam to fit the base and made the duck board from balsa wood using dimensions taken from the Imperial War Museum and scaled down to 1/9th. (200mm).
Then cut the foam into a more interesting shape.
Coloured the duck board with Vallejo wash brown. And used MIG mud for the foam base. I have gradually put in the tread wear with light brown and grey pigments applied with a brush. Gave it a try on the base, then put in the nail holes.
I decided to break one of the rungs of the duck board and began to fill under the board with Vallejo still water effect. I will build up this in layers allowing it to dry between coats.
Have got some rats which look very accurate in the scale I'm using so I may give them a try.
PostSubject: Re: 200mm WWI British infantry.   Sat 17 Oct 2015, 6:36 pm
I like the broken board and the lighter center on the boards makes them look well trod upon. Nice. Super Nice.
PostSubject: Re: 200mm WWI British infantry.   Sat 17 Oct 2015, 7:55 pm
Thanks ZB. Thanks for your continued interest and support.
G.
Page 6 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
» Master Box British Infantry in action N/A WW-II
» British Infantry 1916
» Gigi British
» Ultracast British Empire Munition Boxes B166
» Your All Time Favourite Comic: a Poll (category 8: British Newspaper Strips part 1)
