 1935 Mercedes-Benz 500K
1935 Mercedes-Benz 500K - Page 3 Empty
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeMon 18 May 2015, 5:20 pm
I would go for the darker colour for a more subtle contrast. All depends what floats your boat Al.
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeMon 18 May 2015, 6:34 pm
Looks good Al. I didn't realize the engine sat that far forward in these cars. I bet steering it really built up the biceps.
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeTue 19 May 2015, 11:46 am
Looking great !!!
1935 Mercedes-Benz 500K - Page 3 2776978727
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeSat 30 May 2015, 11:33 pm
Well, something had to go wrong. 1935 Mercedes-Benz 500K - Page 3 1757741307
1935 Mercedes-Benz 500K - Page 3 00141
1935 Mercedes-Benz 500K - Page 3 00232
1935 Mercedes-Benz 500K - Page 3 00335
Something is sadly amiss here. Front track is far to wide. Rear is the same but less so.
I thought I'd done something wrong but look at the instructions and the chassis, hard as I might, I just don't see it.
Time to get my thinking noggin on methinks.
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeSat 30 May 2015, 11:59 pm
Oh Boy!!!
Took yet another look at the instructions and the penny finally dropped.
The brake drum backing plates are dished and I got them the wrong way round. The dish should go into the drum and I have fitted them sticking out of the drum. Hence the front track is way to wide.
I've managed to get the offending parts of the front suspension without damage but now I need to separate the stub axle assembly from the backing plate, along this join
1935 Mercedes-Benz 500K - Page 3 00427
in order to reverse them. Trouble is, they are on with MEK.... not CA so the freezer trick won't work I doubt.
Any suggestions gang?
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeSun 31 May 2015, 5:13 am
Sacrifice the backing plates & save the the uprights?
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeSun 31 May 2015, 5:14 am
I have had success with using a little pressure while applying more MEK. The new MEK loosens the old for a second while its melting. Then pull it apart.
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeSun 31 May 2015, 2:37 pm
Yes, more MEK. Place lightly at the joint once or twice to soften the joint edge and then try to get an XActo blade into the joint.
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeSun 31 May 2015, 2:55 pm
Thanks for the heads up guys.
I should've realised that myself as I've had parts come off before, when re-applying MEK. After all, it's a solvent!! DOH!!
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeSun 31 May 2015, 4:44 pm
That paint job is AWESOME Sir, such a deeeeeeep shine...
As for the DOH moment, I guess it's just one of those things, I've lost count how many time's I've done similar...
Andy... popcorn
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeSun 31 May 2015, 5:07 pm
I agree, more MEK will soften the parts and make it way easier to get apart.
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeSun 31 May 2015, 6:34 pm
Well, re-applying MEK worked well. Didn't need to use an Exacto blad to prise them apart either. Just needed to push with my fingers.
1935 Mercedes-Benz 500K - Page 3 00111
I did break one of the steering arms but that is an easy fix.
Just need some cleanup and then re-assemble.
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeSun 31 May 2015, 7:35 pm
1935 Mercedes-Benz 500K - Page 3 1705482731
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeSun 31 May 2015, 11:19 pm
Oh man!  Measure twice cut once, the carpenters say.  Check instructions twice, glue once, seems the motto today.  Good luck with repairs.
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeMon 01 Jun 2015, 10:50 pm
Well it's fixed.
The front track still looks a tad too wide to me but at least now the tyres are tucked under the wings. I had to narrow the rear axle by 1.5mm per side to get the rear wheels tucked under too.
The front brake backing plates need touching up yet and I also need to re-install the tie rod.
1935 Mercedes-Benz 500K - Page 3 00511
1935 Mercedes-Benz 500K - Page 3 00310
1935 Mercedes-Benz 500K - Page 3 00410
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeMon 01 Jun 2015, 11:53 pm
Couldn't resist a mockup. Everything is fitting beautifully!
1935 Mercedes-Benz 500K - Page 3 00411
1935 Mercedes-Benz 500K - Page 3 00311
1935 Mercedes-Benz 500K - Page 3 00210
1935 Mercedes-Benz 500K - Page 3 00113
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeTue 02 Jun 2015, 1:47 am
What a beauty Al !
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeTue 02 Jun 2015, 11:43 am
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeTue 02 Jun 2015, 2:42 pm
Looking better and better.  Nice save on the front wheels!
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeTue 02 Jun 2015, 3:54 pm
Looks great Al.
It is interesting how far back in the chassis the engine sits. Also to see how far forward the front axle is. The great result of this combination is the flowing lines of the front fenders. Beautiful!
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeTue 02 Jun 2015, 5:35 pm
Super nice. I agree with Pete on the engine placement.
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeWed 03 Jun 2015, 6:59 pm
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeThu 04 Jun 2015, 12:18 am
Beautiful, Al. Are you doing whitewalls?
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeThu 04 Jun 2015, 12:23 am
Thanks Mike.
No to whitewalls Mike. The 60's restoration car had them but the original car as given to Caracciloa by Mercedes Benz didn't have them:
1935 Mercedes-Benz 500K - Page 3 Wheels10
PostSubject: Re: 1935 Mercedes-Benz 500K   1935 Mercedes-Benz 500K - Page 3 Icon_minitimeThu 04 Jun 2015, 1:52 am
I can see where the front wheels sit in that foto.  I wonder if there's significance to the license number.
Skid's  :: Works In Progress :: Road cars-
