 Sd.Kfz.223 Leichter Panzerspahwagen (Fu)
PostSubject: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Tue 07 Apr 2015, 1:31 am
Phew... what a mouthful!!!!
Anyway, I started this one about a year back but for some reason it got put back into the box. Time to get it out again methinks.
1:35 Tamiya kit:
Construction I'd say is at about 50%
Tonight I did some basic detail painting on the control panel:
Typicaly, it's not easy to see when the hull is closed up but it CAN be seen so it had to be detailed a little.
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Tue 07 Apr 2015, 12:46 pm
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Tue 07 Apr 2015, 5:14 pm
Kwel.
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Thu 09 Apr 2015, 4:54 pm
Construction is complete......
......... and with all the stowage etc mocked in place......
The eagle eyed will spot that I have removed the P/e mesh on the turret and used the styrene frame with some me supplied mesh. The P/e just looks far too perfect and fine in this application IMO.
....... all of which will be removed for painting and weathering the vehicle.
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Thu 09 Apr 2015, 5:07 pm
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Thu 09 Apr 2015, 10:04 pm
I would love to go camping is something like this. You could blow up feral pigs and foxes without leaving the vehicle
It has such a long name and then at the end of it, it tells you 'Fu', not very nice.
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Fri 10 Apr 2015, 1:01 am
Now the real fun begins: Weathering.
As it's going to be a desert vehicle, there is not going to be any rust but rather 'chipping'.
After priming I applied two coats of Tamiya Dark Grey (XF-24) which will be the colour of the 'chipping'
Then, using a small piece of sponge dipped in Liquid Maskol.....
....... I dabbed it on all the ridges/high spots where I thought chipping would occur:
I'll leave it to dry overnight and apply the main colour tomorrow.
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Fri 10 Apr 2015, 5:40 pm
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Sat 11 Apr 2015, 1:11 am
Next I gave it two light coats of white just to prevent the dark grey darkening the Dark Yellow too much. This was followed by some pre-shading with matt black:
Next I covered the white areas in Tamiya Dark Yellow:
This was followed by several light mist coats until I had the preshading where I wanted it:
Finally for tonight, I removed the Maskol with Blu Tak to reveal the chipping:
In the photos I see a few areas where I missed removing the Maskol. I may yet remove them OR leave them as is to represent flaking paint!!
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Sat 11 Apr 2015, 12:53 pm
Great job and a nice little "how to"
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Sat 11 Apr 2015, 1:13 pm
Great job Al.  Very,very nice weathering!  When are you going yo start the Tiger???  I want to sit at the feet of the master on that one!
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Sat 11 Apr 2015, 2:23 pm
Railing around the outside, round hole in the top, it DOES look like a "spa-wagon."  Just fill with water and let the desert heat it and you've got a hot tub!  Some beer, watch the sun set over the desert, now that's camping!
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Sat 11 Apr 2015, 4:14 pm
Nicely done. the effect is very realistic. Nice job Al.
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Sun 12 Apr 2015, 11:29 am
Not sure yet John but my build year planner has nothing penciled in for July, so maybe then!!
A small but significant update I feel.
The styrene camo net roll, left a lot to be desred I feel, so I covered it with a layer of common old style bandage.
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Sun 12 Apr 2015, 12:03 pm
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Sun 12 Apr 2015, 12:39 pm
that looks good............dyed with tea?
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Sun 12 Apr 2015, 2:53 pm
Nice work, Al.
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Mon 13 Apr 2015, 1:31 am
I should be ready for the Tiger I by then too. We have to talk.....
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Mon 13 Apr 2015, 1:56 pm
Do i hear a multiple Tiger build in the making? .... i could be persuaded if the invites there.
Nice job on the cargo netting, i have the same question as Paul ..... Tea??
Always good to have a couple of assam teabags to stew and use in weathering, easy way to create old stained wood from stirrers and lollysticks
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Mon 13 Apr 2015, 4:43 pm
dyed with tea? wrote:
Nope!!.... in this case sprayed with Tamiya Dark Yellow same as the vehicle.
Do i hear a multiple Tiger build in the making? .... i could be persuaded if the invites there. wrote:
I don't see why not Colin, assuming John is cool with it. We could make it a Member Group Build.
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Mon 13 Apr 2015, 5:51 pm
I didn't want to intrude ...... but i've always had a King Tiger build lurking in the back of my mind
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Tue 14 Apr 2015, 6:34 pm
All the little doodads added.
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Wed 15 Apr 2015, 6:05 pm
Looking good. The chipping effect looks spot on.
JohnV
PostSubject: Re: Sd.Kfz.223 Leichter Panzerspahwagen (Fu)   Thu 30 Apr 2015, 1:25 am
Wow like that camo job. That burlap sack looks so
real! Beautiful work.---John
» Sd.Kfz.223 Leichter Panzerspahwagen (Fu)
