 C-130H USCG---Revell 1/144 C-130 kit
JohnV
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Wed 20 May 2015, 5:17 pm
I scratch built a nose gear door. Will be masking and painting wing
and fuselage top walkway gray next.---John
JohnV
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Fri 22 May 2015, 10:17 pm
The wing and fuselage walkways are painted, wheels painted and cast
metal props are filed and sanded of the rough spots.---John
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Sat 23 May 2015, 10:37 am
It's looking good John. If you have an airbrush I would recommend a Gunze brand white rather than the Tamiya one which is difficult to use if you need to use it with a paint brush at any stage, touching up etc. As the other guys said, mix it with some black to 'scale it'.
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Sat 23 May 2015, 5:41 pm
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Sun 24 May 2015, 1:38 am
Hope the paint(s) cover the metal well.  Sometimes metal can be fussy.  Best o' luck!
JohnV
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Mon 25 May 2015, 2:04 am
Props painted.---John
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Mon 25 May 2015, 3:06 pm
JohnV
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Tue 26 May 2015, 7:11 pm
I masked, painted airframe white, unmasked and did some touch up.
I still need to paint the nose, window framing and mask and paint the
orange on the wings and tail.---John
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Tue 26 May 2015, 10:02 pm
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Tue 26 May 2015, 10:14 pm
Lookin good!
JohnV
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Wed 27 May 2015, 7:38 pm
Nose job. I also painted window frames and fuel tanks. I still have
more touch up on the windows.---John
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Thu 28 May 2015, 5:40 pm
popcorn
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Fri 29 May 2015, 3:05 am
Looking good
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Fri 29 May 2015, 12:13 pm
Decals will perk up the look.  Looking forward to the completion.
JohnV
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Fri 29 May 2015, 3:29 pm
Speaking of decals where can I get solid color decal sheets? I want to cut
shapes out, triangular and rectangular for the areas on the wings and tail
that are suppose to be painted orange. I want to save time and masking
tape by decaling. Do single color sheets cut pretty good? Use sharp X-Acto
or Ice Scissors? I have the black area behind the jet exhausts on the wing
bottoms painted.---John
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Fri 29 May 2015, 6:42 pm
Good question on the decal sheets. never heard oif them but they might exist. If not could it be done with tape? I see Duct Tape in a bunch of colors at Walmart.
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Fri 29 May 2015, 9:16 pm
It coming along nicely John,
I can onky suggest thin coloured tape cut to shape for the decals, its the way id go most likely.
JohnV
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Sat 30 May 2015, 12:19 am
Thanks, wheels and fuel tanks on.---John
JohnV
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Sat 30 May 2015, 8:23 pm
Microscale make solid color decal sheets, primarily used on model trains.
Have dayglo orange.---John
http://www.microscale.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=MD&Product_Code=TF-29&Category_Code=TF
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Sun 31 May 2015, 11:42 pm
Rather than fussing with and trying to get decals to settle down on surfaces, I'd rather mask and spray paint if possible.  Seems less effort and repainting is easier than re-doing decals that may fail.  Decals are pretty limited in colors too. Just a thought.
JohnV
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Mon 01 Jun 2015, 12:28 am
Not contours , all flat surfaces. It is much harder to get masking tape
to settle down and not have paint run under masks. I much prefer decals
to masking and spraying, no fuss no mess, no airbrush to clean, no paint
bottles to spill, no worry about spitting or splattering or the wrong air pressure
and no ridge from build up of paint thickness. Just so simple to me and they have
the EXACT color I need, dayglo orange.---John
JohnV
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Sat 13 Jun 2015, 9:55 pm
The kit decals were old. They broke into small pieces when they hit the water. I
think I have found replacements for them, a fellow modeller on another site has the
decals for the Minicraft 1/144 C-130 USCG and is not using them. The only draw back
is the Minicraft decals are more red than orange like they should be. The good part is
they have all the decals necessary for the wings, tail and fuselage. Absolutely NO masking
or painting required. Hopefully I will have this finished by the end of the month. I just finished
cutting paper clips for prop shafts and have done a "test fit". All looks good so far.---John
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Sun 14 Jun 2015, 6:47 pm
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Sun 14 Jun 2015, 11:38 pm
If one can get decals in the right color (or print them yourself), that's fine.  Old delicate decals can be saved with a clear coat of (IS IT CLEAR LACQUER?).  Must be on the web somewhere.  As to masking, I think it's a skill too.  The right tape matters and I think somebody suggested automotive masking tape.  It's way more than needed and pricey, but a roll last a long time.  Propellers help give character to the plane.  More decals will take away some of the bland look it still has.
JohnV
PostSubject: Re: C-130H USCG---Revell 1/144 C-130 kit   Sat 20 Jun 2015, 12:08 am
Donor decals from Minicraft are in. I have it better than 1/2 done. Once
I finish decals I can touch up paint, make antenna wires, and add props.
It should be finished early next week.---John
» C-130H USCG---Revell 1/144 C-130 kit
» Revell 1/6 Dodge 426 Hemi
» Revell Aqua
