 Slingster Dragster
Go to page : 1, 2, 3  Next
PostSubject: Slingster Dragster   Tue 13 Jan 2015, 3:36 am
While I'm waiting for things to dry on the C.B. I thought I would find the dragster to go with it and I did. Monogram's reissue of the sizzler
Box art
Parts count
I'll doing the Slingster version with one mod. Won't have a 392 Hemi but will have a injected 427 SOHC and be painted the same color as the 40 Ford SD along with a Testors trailer
Been wanting to build this for a long time so here goes
PostSubject: Re: Slingster Dragster   Tue 13 Jan 2015, 5:23 am
Sounds like a GREAT combo !!
PostSubject: Re: Slingster Dragster   Tue 13 Jan 2015, 10:57 am
Good luck with it John.
I like the Bantam body best.
PostSubject: Re: Slingster Dragster   Tue 13 Jan 2015, 11:36 am
Hi John,
Hope you have stocked on popcorn and KFC Sir...
Andy... popcorn
PostSubject: Re: Slingster Dragster   Tue 13 Jan 2015, 1:06 pm
Looks so similar to the dragster in the "Double Dragster" kit (dragster and Fiat). I'd opt for the competition coupe version as an early '60s machine. I will be at the finish line waiting for this one!
PostSubject: Re: Slingster Dragster   Tue 13 Jan 2015, 9:46 pm
I have this kit but haven't opened it up yet. Now I don't have to. Can't wait to see your take on it.
PostSubject: Re: Slingster Dragster   Tue 13 Jan 2015, 9:52 pm
Dont know what any of that means but looking forward to the build anyway.. Hope it works out for you
PostSubject: Re: Slingster Dragster   Wed 14 Jan 2015, 2:09 am
Thanks for the kind words guy's
Got started on the frame which I heard was a real pain to do, just used 3 of the center cross members to start. after cleaning them and the frame rails I glued them together, then I used the bottom cockpit floor to keep it straight
then I set the bottom front panel on just to double check the frame
so far so good as they say. Going to use the 427 SOHC from a Mustang AFX kit, already has the injection manifold but has a 4 spd. which I will be taking off and using the in/out box that comes with the kit ( have to cut it off the hemi block and cut the 4pd off the SOHC ) then put it in a bag and shake real hard ...... done ( right )
Should have some more done by this week end I hope
Art Laski
PostSubject: Re: Slingster Dragster   Wed 14 Jan 2015, 2:55 am
Awesome! I was going to build one of these for the GSL this year, but I just won't have time. So I am just going to watch your build instead!
PostSubject: Re: Slingster Dragster   Wed 14 Jan 2015, 9:15 am
Looking good John. Frames like these can often be tricky to assemble but it looks like you've done a good job.
PostSubject: Re: Slingster Dragster   Wed 14 Jan 2015, 10:16 am
A good start, getting this first lot straight is going to provide a good foundation for the rest of the build.
PostSubject: Re: Slingster Dragster   Thu 15 Jan 2015, 3:36 am
I got the front axle mount in after 3 tries and then I sanded off the pins for the frame for the 3rd try and got it straight, taped the bottom front panel on so it would stay straight
got the in/out box cut off the hemi, added a .015 plate on the engine side and glued the box to the clutch hosing
got the 4 spd cut off the SOHC and cut the molded on starter off also ( no starter just push start ) then I filled the hole with 2 strips of plastic and a little filler putty, haven't finished it off yet but this is where I'm at
got the chrome eng. parts being dechromed and if I have a chance will work on it tomorrow .
After about 2 hrs. of searching I fond the trailer and yes it was at the bottom of the pile, normal
Thanks for looking and til next time
Old Coyote
PostSubject: Re: Slingster Dragster   Thu 15 Jan 2015, 3:38 pm
Looking good Mike ........ will be following this one with great interest
PostSubject: Re: Slingster Dragster   Thu 15 Jan 2015, 4:35 pm
Excellent progress. Keep it coming.
Grouchy
PostSubject: Re: Slingster Dragster   Sun 18 Jan 2015, 12:37 am
Good looking start to this build.
I recently picked this kit up, but have not opened her up yet. I will watch & learn of the trouble spots from your build....
PostSubject: Re: Slingster Dragster   Tue 20 Jan 2015, 3:10 am
Haven't come across any issues yet
Been working on the 427 SOHC, Have a couple more things to get done and find a fuel pump so far this is where I'm at
and the mag. and crank damper
and both 427's waiting for their home to get done ( 40 SD and this one )
got a little more to do on both engines and I'm working on the frame and body which is about ready for paint.
Thanks for looking and your nice comments
PostSubject: Re: Slingster Dragster   Tue 20 Jan 2015, 11:51 am
looking good! I prefer the blue block, more character. Will be good to see them finished and in place. Good luck in your horsepower quest!
PostSubject: Re: Slingster Dragster   Wed 21 Jan 2015, 8:21 pm
I got the body panels ready for paint and it came to me that I never had the eng. in the chassis or with the body panels on so here is what they look like mocked up
the only thing I had to do was sand some off the bottom of the oil pan ( which needs a little more ) and it fit in their pretty good. Going to have a paint day soon and see what it looks like then
PostSubject: Re: Slingster Dragster   Wed 21 Jan 2015, 8:52 pm
That is sweet.
PostSubject: Re: Slingster Dragster   Wed 21 Jan 2015, 10:48 pm
It's looking great John.
Are the stacks the same electrical bootlace ends I use?
Grouchy
PostSubject: Re: Slingster Dragster   Thu 22 Jan 2015, 12:03 am
John,
I am LOVING the insanity of this!! Tiny frame , BIG engine...That is just so RIGHT!
That may be a GOOD name for this digger..."INSANITY"
PostSubject: Re: Slingster Dragster   Thu 22 Jan 2015, 2:09 am
Al, I really don't remember where or when I got these at
I do remember that they had 7", 10" and 12" stacks and I got some of the 7" & 10" and these are the 10" ones
Grouchy, I haven't even thought about a name yet but the short wheel base and the SOHC would be a hand full with the in/out box
PostSubject: Re: Slingster Dragster   Fri 23 Jan 2015, 3:56 pm
Small up date, Got the SOHC done and ready to go in the chassis
Going to work on the chassis today and if things go right I'll paint the body panels tomorrow
Thanks for looking
PostSubject: Re: Slingster Dragster   Fri 23 Jan 2015, 6:04 pm
the engine is looking good John.
PostSubject: Re: Slingster Dragster   Fri 23 Jan 2015, 9:00 pm
popcorn
Slingster Dragster
» Slingster Dragster
» Red Eliminator 2 Dragster
» Rare Red Cox Dragster .049 Eliminator 2
» Top Fuel Dragster, Revell 1/25 scale
» SOHC Front Engine dragster
