 French Galley La Reale
French Galley La Reale Empty
PostSubject: French Galley La Reale   French Galley La Reale Icon_minitimeTue 18 Nov 2014, 8:49 pm
Here is the second of the $2 ship buys during my LHS closing.  It's the French Galley La Reale.  It was the flagship of the French galley fleet in the 17th century under Louis XIV.  La Reale ('the Royal') referred to a class of galleys, larger than the normal galley.  Kingdoms of Venice, Cyprus, Corsica, Malta and even the Pope referred to their flagships as La Reale. Galleys were the predominant large ship from the BC era to the emergence of the frigate around 1700.
This looks like a nice kit.  It does have slight injection marks here and there.  There are also noticeable seam lines on delicate parts like the oars.  It comes with colored paper decorations for flags, banners and the tented areas.
French Galley La Reale Reale010
French Galley La Reale Reale011
French Galley La Reale Reale012
French Galley La Reale Reale013
Hopefully, this should be another quickie fun build.
PostSubject: Re: French Galley La Reale   French Galley La Reale Icon_minitimeWed 19 Nov 2014, 10:40 pm
Nice subject, sure does look small.
PostSubject: Re: French Galley La Reale   French Galley La Reale Icon_minitimeWed 19 Nov 2014, 10:49 pm
Wow mike, you really have your floaty boaty head on just now. Good luck with all those oars!!
PostSubject: Re: French Galley La Reale   French Galley La Reale Icon_minitimeThu 20 Nov 2014, 7:47 pm
Yipes, less than 6 inches long (?). Good luck. You'll be dreaming of oars before you finish!
PostSubject: Re: French Galley La Reale   French Galley La Reale Icon_minitimeFri 21 Nov 2014, 12:36 pm
French Galley La Reale 3331969777
PostSubject: Re: French Galley La Reale   French Galley La Reale Icon_minitimeSat 22 Nov 2014, 3:46 am
Started work on the rowing deck first.  The oars had a noticeable seamline from a misalignment of the mold halves.  It would have been easier to fix that if I had only left the piece attached to the sprue, but my hands went to work before my brain.  LOL  So, I had to carefully scrape each oar side with a new #11 blade until they looked acceptable.
The seam is noticeable here after sanding.  What looked clean reappeared after priming.  I went over it again scraping with a new #11 blade.
French Galley La Reale Reale014
I AB'd the oars with header white laquer and hand painted the rest.
French Galley La Reale Reale015
The bottom of the hull is also header white.  Above the waterline will be blue.
French Galley La Reale Reale016
Thanks for looking in,
PostSubject: Re: French Galley La Reale   French Galley La Reale Icon_minitimeSat 22 Nov 2014, 10:01 am
Man those oars are looking outstanding. Painting the black tips to all those ropes must have tested your patience. Nice work.
The oars may have been a pain Mike but attention to detail, always pays of in the end.
PostSubject: Re: French Galley La Reale   French Galley La Reale Icon_minitimeSat 22 Nov 2014, 5:46 pm
Very nice work. I agree the painting must have been a test.
PostSubject: Re: French Galley La Reale   French Galley La Reale Icon_minitimeMon 08 Dec 2014, 6:57 pm
It's been a little while since the last update on this one.  I now realize I did quite a bit of small steps without taking pictures.  Befitting a flagship of such a flambouyant time in France, I decided to use some old leftover gold leaf for the gold areas of the ship.  It didn't go quite as I hoped, but it is what it is.  The sails were striped using a fine tipped marker and then fogged over with matt finish with a few drops of white diluted.
French Galley La Reale Lareal10
French Galley La Reale Lareal11
The gold still needs a little cleanup in the portholes. The rigging tilts the front mast some to try to upright the sail. The standard mounting pins make the sail's tail drag on deck.
Thanks for looking,
PostSubject: Re: French Galley La Reale   French Galley La Reale Icon_minitimeMon 08 Dec 2014, 7:09 pm
Mike my friend, you are being WAY to hard on yourself. That looks gorgeous. It really does. Nice one.
PostSubject: Re: French Galley La Reale   French Galley La Reale Icon_minitimeTue 09 Dec 2014, 12:51 am
Ditto what Al said. I think it rocks. French Galley La Reale 3887228019
PostSubject: Re: French Galley La Reale   French Galley La Reale Icon_minitimeWed 17 Dec 2014, 12:47 am
Finished it up today.  Boy, those French sure sported a lot of flags and banners.  Added EZLine for rigging.
Thanks to everyone for looking and for your comments.
PostSubject: Re: French Galley La Reale   French Galley La Reale Icon_minitimeSun 15 Mar 2015, 12:20 am
That's really cool. with all those oars, i bet that thing gets through he water pretty quickly.
PostSubject: Re: French Galley La Reale   French Galley La Reale Icon_minitimeWed 08 Apr 2015, 2:46 pm
I bet the men joining up in the navy then thought of glamorous days in foreign ports, not stuck rowing for days!  Great job, very beautiful.
PostSubject: Re: French Galley La Reale   French Galley La Reale Icon_minitimeWed 22 Apr 2015, 9:40 pm
Beautiful model Mike. French Galley La Reale 1705482731
Skid's Place :: Works In Progress :: Ships-
