 1/144 Little Aircraft Buildoff
PostSubject: 1/144 Little Aircraft Buildoff    Fri 14 Nov 2014, 12:04 am
It looks like I am first to land so I'll kick off the finished models thread with my  Revell Junkers Ju 52/3m in Russian front winter camo.
It is a pretty decent little kit with no reall issues. It was a pleasant surprise to find the kit provided skis as well as wheels, which of course prompted the winter camo.
I made a simple base from sheet styrene, coated in thick PVA glue and then a shed load of this...........
................. dumped on top, just like flocking in a car. I'm impressed with it as it's a lot tougher than using baking soda.
There was supposed to be an antenae mast in the kit but it was missing or the carpet monster got it, so I had to make one. The radio wire is EZ line.
And for scale, a shot with the standard international measuring device.
PostSubject: Re: 1/144 Little Aircraft Buildoff    Fri 14 Nov 2014, 7:37 am
Nice one Al. Reminds me of the getaway plane used in the film 'Where Eagles Dare'. Now let's see....ummm.....that microscopic canopy....turned out OK!
PostSubject: Re: 1/144 Little Aircraft Buildoff    Fri 14 Nov 2014, 8:26 am
Very striking against that awesome white base.
PostSubject: Re: 1/144 Little Aircraft Buildoff    Fri 14 Nov 2014, 5:18 pm
Broadsword caling DannyBoy......................Broadsword calling DannyBoy'
PostSubject: Re: 1/144 Little Aircraft Buildoff    Fri 14 Nov 2014, 5:47 pm
, Snow looks very realistic and the plane is very nice.
PostSubject: Re: 1/144 Little Aircraft Buildoff    Fri 14 Nov 2014, 5:50 pm
Nicely done Al
PostSubject: Re: 1/144 Little Aircraft Buildoff    Sat 15 Nov 2014, 3:39 am
So well done. Maybe there ARE no bad models, just untalented builders! You showed even the simplest kits can yield great results. The base idea is simply genius! Take a bow.
PostSubject: Re: 1/144 Little Aircraft Buildoff    Sat 15 Nov 2014, 10:58 am
Great mini plane Al.. Looks fantastic
PostSubject: Re: 1/144 Little Aircraft Buildoff    Sat 15 Nov 2014, 7:44 pm
Landing No2.
I did this one in winter camo for two reasons. 1st I didn't want to do the same scheme as Colin did his in and 2nd it was a lot easier!!! LOL
I added the radio wire and covered the canopy and gunners position in a tarp.
PostSubject: Re: 1/144 Little Aircraft Buildoff    Sun 16 Nov 2014, 4:10 pm
PostSubject: Re: 1/144 Little Aircraft Buildoff    Mon 17 Nov 2014, 12:14 am
Cheers Buck.
PostSubject: Re: 1/144 Little Aircraft Buildoff    Mon 17 Nov 2014, 12:30 am
That looks awesome Al !!!
PostSubject: Re: 1/144 Little Aircraft Buildoff    Mon 17 Nov 2014, 2:51 am
They ARE small. Maybe not "braille scale," but hard to make look realistic. Excellent work chaps!
PostSubject: Re: 1/144 Little Aircraft Buildoff    Mon 17 Nov 2014, 11:12 am
They both look great !!
PostSubject: Re: 1/144 Little Aircraft Buildoff    Mon 17 Nov 2014, 12:03 pm
Nicely done Al, looks very crisp and neat.
PostSubject: Re: 1/144 Little Aircraft Buildoff    Mon 17 Nov 2014, 12:50 pm
Both are stunning Sir, especially for the size, have you made two display bases or is it the same one used for both...
PostSubject: Re: 1/144 Little Aircraft Buildoff    Mon 17 Nov 2014, 4:30 pm
Harron.... 1:72 in normally referred to as brail scale, which mkes this twice as small. 1/8th if you talk about 'bulk'. LOL
Two bases Andy. There is quite a difference in size:
PostSubject: Re: 1/144 Little Aircraft Buildoff    Tue 18 Nov 2014, 2:30 pm
Here's my first.
Had a blast at doing the rigging.
PostSubject: Re: 1/144 Little Aircraft Buildoff    Tue 18 Nov 2014, 3:23 pm
Nice one, Colin. How brave of you to take on the rigging. Great work.
PostSubject: Re: 1/144 Little Aircraft Buildoff    Tue 18 Nov 2014, 4:44 pm
That rigging had to be a royal pain. Nice work.
PostSubject: Re: 1/144 Little Aircraft Buildoff    Wed 19 Nov 2014, 12:55 pm
As to thread vs. wire or filament fish line, each has its points. Tho I haven't tried it, polyester thread and polyester wrapped around cotton thread may be the best compromises. It's hard to get wire or fish line to look taut. Great work so far. Am waiting for the biggies yet to come. The bomber and Catalina will be cool too!
PostSubject: Re: 1/144 Little Aircraft Buildoff    Wed 19 Nov 2014, 5:27 pm
That's a tiny model to rig Colin. You did will to do it.
PostSubject: Re: 1/144 Little Aircraft Buildoff    Wed 19 Nov 2014, 6:18 pm
how on earth you did that rigging is beyond me......id not tackle it in 1/72!
once the Ducati is done i can get back to my 110
Skid's Place :: Community Builds :: Members Group Builds Finished Models-
