 1930 Bentley Silver Aero
Go to page : Previous  1, 2
1930 Bentley Silver Aero - Page 2 Empty
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeSun 05 Oct 2014, 2:03 am
The engine looks so cool. I like different and this one is just that. Not in a bad way either.
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeSun 05 Oct 2014, 2:24 am
1930 Bentley Silver Aero - Page 2 1705482731
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeSun 05 Oct 2014, 3:47 am
Andy, Dave is right. I've tried a spot touch-up on an airbrushed piece in the past and it didn't even match. If you brush Alclad on, you'll get stroke marks that are almost impossible to overcome. I've had better reults trying to brush paint MM Metallizer, but again not over large areas.
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeSun 05 Oct 2014, 4:56 am
Thank you Dave and Mike, it was just a passing thought after seeing your radiator shell, with it being so small thought you might have used a normal brush...
Thank you again...
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeTue 07 Oct 2014, 10:48 pm
No exhaust just yet, but did get a hand lever and steering linkage on.
1930 Bentley Silver Aero - Page 2 Bentle28
Also got the spare mounted after grinding off the taillights for clearance.  Will add scratchbuilt lights to the styrene rod across the top of the gas tank.
1930 Bentley Silver Aero - Page 2 Bentle29
Thanks for looking,
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeTue 07 Oct 2014, 11:08 pm
The tires look Gray and not black. Is that a camera trick or did I miss something. Love this build.
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeWed 08 Oct 2014, 12:37 am
I think it's looking great Mike but do my eyes deceive me, or are the front left and rear right tyres bald???
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeWed 08 Oct 2014, 3:12 pm
Buck, I didn't like how they looked when I painted the whole wheel gloss black and then did the tires in matt finish. Looked like a big blob of blackness. Normally I would have used the Vallejo Black-Grey for just the tread area.
Al, it's probably a combination of Pyro's molding and me filing a bit to eliminate any noticeable ridges (two piece tires). Hopefully, the front fenders will hide that a bit.
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeThu 09 Oct 2014, 12:28 pm
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeSun 12 Oct 2014, 12:02 am
I've decided on an exhaust system - finally.
I tried cutting and gluing an old manifold to my pipes, but it didn't quite give me what I wanted.
1930 Bentley Silver Aero - Page 2 Bentle30
1930 Bentley Silver Aero - Page 2 Bentle31
Then I tried gluing pieces of home copper wiring to the pipes, but I couldn't get the bends even enough.
1930 Bentley Silver Aero - Page 2 Bentle32
So I decided to use a smaller styrene rod all installed straight and then bent as uniformly as I could.  I also used a smaller header piece to be attached to the long pipes later.
1930 Bentley Silver Aero - Page 2 Bentle33
1930 Bentley Silver Aero - Page 2 Bentle34
I drilled holes in a popsicle stick to insert the pipes, heat all 4 at once and try to bend uniformly.
1930 Bentley Silver Aero - Page 2 Bentle35
And amazingly, I ended up with two sets of pipes that looked quite similar.  Now to decide on the final paint color.
1930 Bentley Silver Aero - Page 2 Bentle36
The chassis now has the radiator installed.  I was holding off to make the hood foldable, but the material is too thin to safely drill into from the edge.
1930 Bentley Silver Aero - Page 2 Bentle37
Also added the taillights made from spare red parts.
1930 Bentley Silver Aero - Page 2 Bentle38
That'll be it for a time while the wife and I spend a few days in Las Vegas.
Thanks for looking,
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeSun 12 Oct 2014, 12:11 am
That thing is just AWESOME Mike !!
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeSun 12 Oct 2014, 12:17 am
Ditto what Sam said Mike and the exhaust look great.
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeSun 12 Oct 2014, 2:20 am
Good idea on bending the header pipes altogether. Looking good.
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeTue 21 Oct 2014, 2:35 pm
Got back to this after a little vacation.  Installed the exhaust system, some radiator hoses, and the motor intake petcocks.  They appear straight, and even match side to side.  The motor half was weathered more than the long pipes - I thought it would show weear from the bulk of the heat and differentiate it as a cast metal versus steel piping.  I'm still thinking that one over.
1930 Bentley Silver Aero - Page 2 Bentle41
1930 Bentley Silver Aero - Page 2 Bentle42
1930 Bentley Silver Aero - Page 2 Bentle43
That's all for now. Thanks for looking,
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeTue 21 Oct 2014, 2:44 pm
Mike: This is looking great. You did an excellent job on the exhaust.
I'm a bit late, but in the future you might consider using solder to fabricate exhaust systems. It can be found in various diameters, forms and cuts easily, glues well with CA or epoxy and looks like metal because it is metal. It's the first thing I reach for when fabricating exhausts.
John
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeTue 21 Oct 2014, 4:55 pm
Looking SWEET !!!
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeTue 21 Oct 2014, 5:22 pm
Nice one Mike. The overhead shot really shows of your work well.
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeTue 21 Oct 2014, 6:04 pm
Outstanding!!!!!
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeThu 23 Oct 2014, 10:48 pm
Getting close to the finish line, here.  Added the dashboard and steering wheel.  Installed the front fenders, but had to cut off the rear support rods.  Made up an insert to fill the space left by the missing blower.  Headlights and roadlights are painted with Alclad Chrome.
1930 Bentley Silver Aero - Page 2 Bentle44
1930 Bentley Silver Aero - Page 2 Bentle45
1930 Bentley Silver Aero - Page 2 Bentle46
Thanks for looking.
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeFri 24 Oct 2014, 3:05 pm
It's looking great Mike, everything works well with everything else!! 1930 Bentley Silver Aero - Page 2 1705482731
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeFri 24 Oct 2014, 6:06 pm
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeWed 29 Oct 2014, 7:05 pm
The Bentley is finished!  The final touches were the shifter, step plates, and windscreens.  I used the small individual windscreens and left the full length one off.  It had a terrible injection mark and Pyro made it as a glass windscreen instead of the screened piece I've seen in online pics.
1930 Bentley Silver Aero - Page 2 Bentle49
1930 Bentley Silver Aero - Page 2 Bentle48
This was great fun with a mediocre kit and it may not be my last Aero car.  I've got a beautiful 15 liter Mercedes DIII waiting for a home.
Thanks for watching and all your comments.
heepey
heepey
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeMon 17 Nov 2014, 5:20 pm
great little build. It seems that some of that lovely green is still peeking out, or is it just the camera playing tricks?
PostSubject: Re: 1930 Bentley Silver Aero   1930 Bentley Silver Aero - Page 2 Icon_minitimeTue 18 Nov 2014, 3:21 pm
Don't see how as everything was primed first before painting. It may be reflections from overhead lighting.
» F/S 2000 GTP silver mist coupe
» Rustoleum..the long term
» Ace RC aerocommander "Shrike"
» [Theory] What did the people on other planets look like/act like in the Silver Millennium?
» Aero 35 Inline
Skid's  :: Works In Progress :: Road cars-
