 Vickers E Mk B Light Tank
PostSubject: Vickers E Mk B Light Tank   Sat 06 Sep 2014, 10:40 pm
so since the Porsche is temporarily on the back burner til I can lay my hands on some paint I thought I would start this as I want to try a few things and don't want to do it to an expensive kit
Vickers E mk B light tank by Mirage Hobby who are a Polish company ive never tried before....picked the kit up at a show for a whopping 4 quid! ($US6.50!!) so I don't mind if it all goes a bit Pete Tong...the guy had quite a few different ones all at the same price, wish i had got more now
http://en.wikipedia.org/wiki/Vickers_6-Ton
I'm actually quite impressed with the quality....not quite Tamiya but comparable to Italerai or best that Revell can do
not sure what scheme I'm going to do.....the two schemes on the instructions are both Polish Army from mid to late 1930's....one is a very difficult one similar to WW2 Japanese type......the other is very similar to late WW2 German tri-colour, which I might do just for the practice, but it might also just go a dark green
since it dosnt come with any figures i might include one out of this lot, will decide when the time comes
PostSubject: Re: Vickers E Mk B Light Tank   Sun 07 Sep 2014, 5:38 pm
Good project.
PostSubject: Re: Vickers E Mk B Light Tank   Sun 07 Sep 2014, 9:00 pm
this is turning out to be a great little kit!
filled up the interior with some big nuts to add some mass to the whole thing, also added a small nut under all that central plasticine with a hole in the bottom of the hull so i can use some thread rod as a handle
ive put together Thomasz the Tank Commander
the kit comes with a modification the Poles did to their tanks,...they found the engines overheated due to lack of airflow so they made some ducting to force air into the engine compartment
PostSubject: Re: Vickers E Mk B Light Tank   Mon 08 Sep 2014, 10:55 am
Nice
PostSubject: Re: Vickers E Mk B Light Tank   Mon 08 Sep 2014, 6:29 pm
PostSubject: Re: Vickers E Mk B Light Tank   Tue 09 Sep 2014, 10:12 pm
so its pretty much together, primed and ready for painting
must admit it, Thomasz is an ugly bugger lol
i was toying with doing a three colour camo scheme but ive settled on just a plain green one
two reasons really, one is this was only ever meant to be a test mule to try a chipping/weathering technique ive never done before so i dont want to over complicate things
the second is, since its just going to be a plain colour i thought id try practicing pre-shading, its something ive never really got to work, mainly cos i think im too heavy handed
PostSubject: Re: Vickers E Mk B Light Tank   Tue 09 Sep 2014, 11:05 pm
Any chance of taking pictures through the stages of pre shading Paul? Be interesting to see the progress as it's something I don't do as a rule as I brush paint.
Thinking of going to the dark side and getting an airbrush.
Looks a nice little kit, and yup he's an ugly so an so..... Like looking in a mirror to be honest.
PostSubject: Re: Vickers E Mk B Light Tank   Wed 10 Sep 2014, 8:15 am
Is good. Is Polish. These prewar subjects are very interesting.
PostSubject: Re: Vickers E Mk B Light Tank   Wed 10 Sep 2014, 5:08 pm
lol...im making this all up as i go along!
basically you spray black lines along edges so when you spray the top coat the black acts like an undercoat and makes it darker
ive never got it to work cos im too heavy handed and just obliterate the black with the top coat lol
to paraphrase a little green fellow when it comes to airbrushes....
do or do not...........there is no think
seriously it really is worth the effort
PostSubject: Re: Vickers E Mk B Light Tank   Wed 10 Sep 2014, 7:24 pm
I've seen some military model painting on the You Tube channel, and it can be fun and interesting. I agree on a one-color scheme. For the experiment it makes sense, and as a relatively small and stubby model, simple is better. Good luck, good price too!
PostSubject: Re: Vickers E Mk B Light Tank   Thu 11 Sep 2014, 8:39 pm
i hope this is going to work lol
stage one of this process is to make what is essentially a enamel paint using matt enamel varnish, enamel thinners and rust pigments
it helps apparently to have different shades of rust
and it dosnt need to be too neat
this will now get a day or so to dry.....cant do anything til saturday afternoon anyway thanks to work getting in the way, i also need enough time to airbrush the three different colours for the camo in one day
im going back to the 3-colour camo as i dont think im going to be able to do the preshading as it will mess up the chipping/rusting technique so i may as well ahve a go at the camo as i do have the three shades needed
PostSubject: Re: Vickers E Mk B Light Tank   Sat 13 Sep 2014, 9:19 pm
im dying to get on with this, things keep getting in the way....like work!
but ive done the adding the latex with a bit of a sponge........might get to put on the base coat of yellow tomorrow, and the brown and green on monday.....then the fun really begins
PostSubject: Re: Vickers E Mk B Light Tank   Sun 14 Sep 2014, 7:37 am
I'm curious to see what happens here, I'm new to this.
PostSubject: Re: Vickers E Mk B Light Tank   Sun 14 Sep 2014, 9:33 am
thats two of us then!
PostSubject: Re: Vickers E Mk B Light Tank   Sun 14 Sep 2014, 10:22 am
Make that three. Never used Maskol on armour.
PostSubject: Re: Vickers E Mk B Light Tank   Sun 14 Sep 2014, 10:33 am
first time ever for me
PostSubject: Re: Vickers E Mk B Light Tank   Sun 14 Sep 2014, 12:04 pm
Looking good so far !
I have used liquid mask and you can get some really nice chipped paint effects with it.
Looking forward to your success !
PostSubject: Re: Vickers E Mk B Light Tank   Mon 15 Sep 2014, 4:57 pm
Liquid mask (frisket) does work well. I've seen the "hair spray chipping" technique on You Tube as well. Good luck!!
PostSubject: Re: Vickers E Mk B Light Tank   Mon 15 Sep 2014, 6:14 pm
over here frisket is a adhesive film that can be cut to shape
done the hair spray technique a few times but im not just after a chipping effect with this
managed to get the camo on today
the instructions show either a Japanese style patchwork camo which looks incredibly difficult or a tri colour stripey one, which i have had a crack at
going to leave it til tomorrow to really dry before piggling off the Maskol
colours are a little bright at the moment but some wash and some matt varnish should tone it all down a bit
PostSubject: Re: Vickers E Mk B Light Tank   Mon 15 Sep 2014, 6:19 pm
Looks good to me.
PostSubject: Re: Vickers E Mk B Light Tank   Tue 16 Sep 2014, 4:04 pm
couldnt wait any longer lol
used a blob of blutac to rub over the surface to remove the maskol and ended up with this
now the interesting bit.............since i used an enamel varnish at the start i can use enamel thinners to reactivate the weathering powders
plan is to try and move the powders around a bit and make some streaks
need to do a bit more cos i think i got heavy handed, need to be more subtle, but then the whole thing was to try out the technique
going to try and clean up the streaks a little, then let it really dry off so i can give it a coat of Kleer, then i can add a wash
PostSubject: Re: Vickers E Mk B Light Tank   Tue 16 Sep 2014, 5:19 pm
Very nice job done!
PostSubject: Re: Vickers E Mk B Light Tank   Tue 23 Sep 2014, 11:24 am
got to the point of adding the tracks
these are probably the weakest thing in the kit. they are about 10mm too long so had to do a little trimming
also wish i had given a dust wash before i attached them.....brain fade moment and cant take them off again cos i had to glue them on
PostSubject: Re: Vickers E Mk B Light Tank   Tue 23 Sep 2014, 12:56 pm
That's looking good, think the tri colour works very well mate. Rusty areas look natural as well.
If it's any help I put the tracks on before their final weathering as a rule then use a fine paint brush with diluted pva painted over where you need the dust, then blow bicarb onto the tracks, tap the excess off and just soak a wash of the colour required into it when the pva has dried.
PostSubject: Re: Vickers E Mk B Light Tank   Tue 23 Sep 2014, 1:42 pm
yeah but then you cant get it in the tracks thats covered by the mudguards
ive managed to get the tracks off without damaging anything else so i can do it how i like to. im not pnning on heavy weathering with lots of mud, just want the tracks to look dirty, not black
» British Light Tank Mark IV C
» Vulcan 1/35 British Light Tank MK VI C
» Italeri - 1/35th Scale Carro Armato L6/40 due in US in January 2009
» Burrell 4" - help required re getting water from tank to boiler
» MY RACKING AN REBUILT TANK
