MkA Whippet WWI Medium Tank 1918 (German capture)
+3
7 posters
Page 3 of 4 Previous  1, 2, 3, 4  Next
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 Empty Re: MkA Whippet WWI Medium Tank 1918 (German capture)
Post by Skid Sun 31 Aug 2014, 4:13 pm
Yes oh slave driver!!!
This makes interesting reading too:
http://en.wikipedia.org/wiki/Medium_Mark_A_Whippet
Been looking at more ref photos and I think I need some heavier weathering.
Post by Guest Sun 31 Aug 2014, 4:32 pm
I skimmed through that a while back (as I do with anything wiki due to the fact any one can edit it), saying that though there's some fortifying evidence for certain dates. And the bit on variants sparked my interest and some further reseach.
Wonder if Walter Gordon Wilson is a distant relative of mine?
Post by Skid Sun 31 Aug 2014, 6:57 pm
Ya never know Colin.
I'm sure I'm not related to Sir Walter Gordon Wilson though!!! LOL
Post by Skid Mon 01 Sep 2014, 12:10 am
I went a bit heavier on the other sponson but still feel it needs a bit more:
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 00156
I also have one silencer done:
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 00352
Post by Geezerman Mon 01 Sep 2014, 8:52 am
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 1705482731
Post by Skid Mon 01 Sep 2014, 11:10 pm
Tracks done.....
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 00157
..... and testors Dullcote applied.
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 00158
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 00258
Post by Guest Tue 02 Sep 2014, 4:19 am
Post by Skid Thu 04 Sep 2014, 1:18 am
I made up a cable using the lead wire form lead core carp fishing line but wasn't happy with the result:
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 Dscn0610
The lead is difficult to get bent to the right sort of shape and the eye fittings are way to big:
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 Whippe10
A rethink was required. Then the penny dropped. What better to represent cable than micro cable. So I stripped some multi core wire and twisted it in my fingers:
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 Dscn0611
Now what to do about those clunky oversized fittings? I Googled 'Tank Towing Cables' and found these 1:16th scale versions:
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 Tiger-11
.... and the penny dropped even further. I hit the Pike fishing tackle box and came up with some metal crimps used for making wire traces when fishing for toothy predators. They are too long but cut easily by rolling under a modeling blade.
Then I thought about using the same wire I use for pike traces for the tank cable. This one is perhaps a bit on the thin side but I'm sure I can come up with something thicker.
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 Dscn0612
Post by Guest Thu 04 Sep 2014, 3:01 am
Good stuff you got going Al. I think both of the bottom cables look great.
Post by Guest Thu 04 Sep 2014, 9:28 am
They both look good.
I keep all of the insulation I take off any wire, always good for making cable ends.....
Slip short bit of insulation over wire, bend end of wire to loop, slip insulation back to cover loose end.
As it's soft plastic it's more versatile that the solid metal types and you can bend and dent it to look weathered
Simple, no faffing and looks as good as any bought ones
Post by Geezerman Thu 04 Sep 2014, 11:14 am
Post by Skid Thu 04 Sep 2014, 4:45 pm
Good tip Coilin... thanks.
Fitted a wooden crate and mounted a tree trunk.
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 Dscn0613
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 Dscn0614
Post by Guest Thu 04 Sep 2014, 6:07 pm
What is the tree trunk for? Fire Wood? Looks good.
Post by Guest Thu 04 Sep 2014, 7:13 pm
Zbuckster wrote:What is the tree trunk for? Fire Wood? Looks good.
To put under the tracks to gain traction in tricky conditions, they're normally the width of the tank so both tracks get purchase, but i've seen some tanks carry two (or more) smaller ones (easier for the crew to manage)
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 Sam_1110
Post by Skid Thu 04 Sep 2014, 11:01 pm
I just knew 'someone' would pick up on that, which is exactly why the crew of just three, decided two logs between them, are easier to man handle than one!!! LOL
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 Dscn0615
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 Dscn0616
Post by Guest Thu 04 Sep 2014, 11:43 pm
Sorry Al, didn't mean it to point out an error or cause you extra work,  I just answered a question without thinking.
Also............ posting some of my work in your thread, a bit rude really in hindsight.
I do like it with the extra log though, looks much heftier!
Post by Skid Fri 05 Sep 2014, 12:39 am
Haddaway ya daft bat!!!
I'm glad you pointed it out 'cos,although it's obvious, I just plain forgot. I always welcome constructive criticism Colin.
As for your tank photo, wish I'd thought about the canvas around the logs!!! Ah well!!
Post by Skid Fri 05 Sep 2014, 11:37 am
The predator fishing trace wire looked too thin to me, so I went searching for an alternative wire that had some 'spring' to it. The copper wire had virtualy none at all.
I found some that was steel coloured, stripped 25mm of insulation, clamped it in a small vice, then gradualy stripped the insulation while simultaneously twisting the wire tight. The result was a nice tight wind of wire which had some 'spring' in it.
This is the end result, which I don't think is too bad at all.
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 Dscn0617
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 Dscn0618
Post by Guest Fri 05 Sep 2014, 11:59 am
That does look better, sits nicely and natural.
Have you tried twisting your own, just a few thin wires wrapped around a nail/screw in the bench and then use a drill/dremel to get a tight twist?
The canvass is kitchen roll, dampened, folded, wrapped round the poles and then a dark green wash is just soaked in and left to dry.
Post by Skid Sat 06 Sep 2014, 9:42 am
Have you tried twisting your own, just a few thin wires wrapped around a nail/screw in the bench and then use a drill/dremel to get a tight twist? wrote:
That's pretty much what I did Colin. The wire inside the insulation was un-twisted.
I found some that was steel coloured, stripped 25mm of insulation, clamped it in a small vice, then gradualy stripped the insulation while simultaneously twisting the wire tight. The result was a nice tight wind of wire which had some 'spring' in it. wrote:
The resin cans arrived from the US to-day and I'm well pleased with them. Even the handles are hollow. Decals for them look good too. P for petrol, W for water and O for oil. $4.99 for nine plus shipping
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 00159
Stock photo:
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 El01611
These arrived in the same delivery and while they look good, they also look a bit tricky to assemble.
$9.99 for six plus shipping
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 00260
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 00353
Both were supplied by: http://www.milminwh.com/  and I found John an easy and nice guy to deal with.
Post by Geezerman Sat 06 Sep 2014, 12:45 pm
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 1705482731 MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 3331969777
Post by Guest Sat 06 Sep 2014, 5:36 pm
I think the box will be cool when you get it together.
Post by Skid Sun 07 Sep 2014, 12:34 am
I finished up the canvas mudgaurds. Thin sheet styrene covered in medical tape.
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 00160
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 00261
I also made a tarpaulin for the rear frame to hold. It was originaly intended to be used in my 'Time For A Brew' dio. Rolled up nasal tissue, fastened with 'rope' and dunked in the used brush cleaning bottle gunge.
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 00446
Finaly, I tied down the netting.
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 00537
For this I used some braided fishing line. However it was too fine and smooth, so I cut a length, trapped one end in my bench vice and ran a coarse sanding stick over it, until I had a more believeable 'rope' texture.
MkA Whippet WWI Medium Tank 1918 (German capture) - Page 3 00733
Post by Geezerman Sun 07 Sep 2014, 10:16 am
Nice detailing, Skid !
Post by coyote Sun 07 Sep 2014, 12:54 pm
Nice work Al.
