 Dual engine Fueler
dadooronron
PostSubject: Re: Dual engine Fueler   Tue 09 Sep 2014, 11:01 am
I'm enjoying this already !
PostSubject: Re: Dual engine Fueler   Tue 09 Sep 2014, 3:55 pm
I see method in your madness Clay. Looks like a plan to me.
PostSubject: Re: Dual engine Fueler   Wed 10 Sep 2014, 5:25 pm
Had no zoomies in my salvage, so will making 2 pair from these.
Made the front frame extensions needed to have some engine mounts. I do believe my imagineering will be stretched to the limit on this pig !
PostSubject: Re: Dual engine Fueler   Wed 10 Sep 2014, 6:14 pm
PostSubject: Re: Dual engine Fueler   Wed 10 Sep 2014, 7:19 pm
This design is just too bizarre, like half of the Tommy Ivo Showboat or a home-made one of the famous dual engine Freight Train. Good luck, the work so far shows you have the idea pretty well along. The steering will be hard to replicate, I'm guessing. What it needed was power steering!
PostSubject: Re: Dual engine Fueler   Thu 11 Sep 2014, 12:00 am
I see what might be a rod passing thru the chassis, but have no idea how the 1:1 steers. Only thing I can think might be a FWD trans axle that I don't know how to model. I wasn't even thinking of trying any steering at all. I have a quick change rear end glued to the bell housing on the front engine. I'll see if I can fake something ??????
Maybe y'all better practice employing the ridicule icon.
PostSubject: Re: Dual engine Fueler   Thu 11 Sep 2014, 12:15 am
It's coming on nicely Clay.
Using a solid axle at the front is going to create massive problems for steering. Better to go with a transaxle and drive shafts.
I can probably scare up a transaxle for you if that would help!!
PostSubject: Re: Dual engine Fueler   Thu 11 Sep 2014, 2:03 am
Thanks, Skid.
That's a lot of trouble when I can be just as happy cobbling up some imagineering.
I think leaving a solid non-steering front might stretch the credulity a bit
PostSubject: Re: Dual engine Fueler   Thu 11 Sep 2014, 2:54 am
Maybe put some outer knuckles on it like a 4x4 front end and then run basic steering rod ?
PostSubject: Re: Dual engine Fueler   Thu 11 Sep 2014, 6:40 am
Differential braking? LOL.
PostSubject: Re: Dual engine Fueler   Thu 11 Sep 2014, 5:34 pm
This production was destined for a comedic outcome from the get-go.
I like Sam's idea and will run with that.
First, (after cutting  the  axle shaft stubs off the quick change box), I made some backing plates from a couple of Chev hubcaps, and got some U joints from a steering shaft.
Next, I needed plates to cover the sides of the  quick change housing. I see no need to hide the identity of these.
PostSubject: Re: Dual engine Fueler   Thu 11 Sep 2014, 5:40 pm
I guess the ideal thing would have been a front differential from a 4X4 truck. Then you would have had all the steering and stuff ready to go.
Like it a lot Clay.
dadooronron
PostSubject: Re: Dual engine Fueler   Thu 11 Sep 2014, 9:22 pm
That would be too easy Buck...'Imagineering' is more fun.
PostSubject: Re: Dual engine Fueler   Fri 12 Sep 2014, 1:12 am
What Ron said !
PostSubject: Re: Dual engine Fueler   Fri 12 Sep 2014, 1:27 am
Glad I could help Clay.
PostSubject: Re: Dual engine Fueler   Fri 12 Sep 2014, 3:23 pm
The triumph of imagineering over the ignominy of defeat !
PostSubject: Re: Dual engine Fueler   Fri 12 Sep 2014, 3:57 pm
TA DA!!!!! Love it.
PostSubject: Re: Dual engine Fueler   Fri 12 Sep 2014, 5:04 pm
Looks great Clay I don't think I would want to be around if it ever did a WHEELIE
PostSubject: Re: Dual engine Fueler   Fri 12 Sep 2014, 7:18 pm
Works for me too!!! Good Imagineering, fer certain!
PostSubject: Re: Dual engine Fueler   Mon 15 Sep 2014, 5:44 pm
Progress report, even though it's just mundane stuff. Been making the engines busy looking with a little detailing and working on the cockpit area. The rear engine is permanently installed in the frame.
PostSubject: Re: Dual engine Fueler   Mon 15 Sep 2014, 6:22 pm
PostSubject: Re: Dual engine Fueler   Mon 15 Sep 2014, 6:32 pm
There ya go Clay, front end is done and dusted. Looks good too.
PostSubject: Re: Dual engine Fueler   Tue 16 Sep 2014, 4:19 pm
Both engines installed. Just need to add a couple of  coils, close in the cockpit sides and put 'er together.
PostSubject: Re: Dual engine Fueler   Tue 16 Sep 2014, 5:20 pm
Looking good!
PostSubject: Re: Dual engine Fueler   Wed 17 Sep 2014, 9:09 pm
She's done. Taking it out of the garage for fotos.
Dual engine Fueler
» Dual Alternator on TBI
» 5.3 LS Vortec Engine and 4L60E Transmission
» Engine of chaos ideas (?)
» Dual wield vs. 2 handed weapons-- Ironing out house rules.
» Cube Engine
