 61 Impala
60s era
PostSubject: 61 Impala    Fri 06 Jun 2014, 6:44 pm
OK   this is a 61 Impala made after  a Real one I owned way back when..It was a
 348cu in -350hp - tri power -4spd -  Original car..
OK maybe I got it. Lets try a pic or two..
  Saddle Tan with off white stripe in center with matching interior - bench seat..
 This is a pic of the interior so far.
Not sure how much I can put into one post , so for now will end and see later.
Thanks     Tom  --  60s era
PostSubject: Re: 61 Impala    Fri 06 Jun 2014, 7:16 pm
Looking very nice Tom.
I stuck them in one post for you.
PostSubject: Re: 61 Impala    Fri 06 Jun 2014, 7:21 pm
Looks good      I like your interior and the carpet looks really good
60s era
PostSubject: Re: 61 Impala    Fri 06 Jun 2014, 7:23 pm
Thanks 2whl.
Still learning how to maneuver this sight ..Have more to post later..
Tom
60s era
PostSubject: Re: 61 Impala    Fri 06 Jun 2014, 7:24 pm
Thanks John..
have a lot more pics to post , just getting used to this sight..
Tom
60s era
PostSubject: Re: 61 Impala    Fri 06 Jun 2014, 7:32 pm
Thought I would throw this shot of the motor in just for kicks -- not done with it yet..
Worst part of the throttle linkage was trying to keep it all under that huge air cleaner.
60s era
PostSubject: Re: 61 Impala    Fri 06 Jun 2014, 7:42 pm
A lot of detail is going into this :
Fuel Lines
Brake Lines
Real Coil Springs Front and Rear. Shocks inside front coils..
Adjustable rear shocks
Generator wired
Voltage regulator wired
Throttle linkage -- Fuel Lines
Heater Hose
Paint is Model Masters Beige w/Model Masters Clear..Car was sanded with 6000 b4 it was Cleared.
All chrome is hand painted MM Chrome Paint. More to come
Tom
60s era
PostSubject: Re: 61 Impala    Fri 06 Jun 2014, 7:47 pm
Some how I double posted the last one ..Can some one tell me how to delete a post or can i even do it ?
60s era
PostSubject: Re: 61 Impala    Fri 06 Jun 2014, 9:14 pm
Who ever Deleted that post... Thank You ...
Is there a way I can Delete a post if necessary ??
PostSubject: Re: 61 Impala    Fri 06 Jun 2014, 11:31 pm
I did it....you're welcome
No, there isn't a way to do it........just leave it and we'll get to it....no problem
PostSubject: Re: 61 Impala    Sat 07 Jun 2014, 12:30 am
Nice way to introduce your work. Sweet looking Chevy. The paint, interior and engine rock.
Put as much as you like in one post no limit here.
60s era
PostSubject: Re: 61 Impala    Sat 07 Jun 2014, 12:35 am
Thanks Z
Heres a little update on the interior.. My orig 1:1 did not have a tachometer in it ,but this model will as the steering column had a notch in it for one and I forgot to fill it....[img][/img]
[img][/img]
[img][/img]
Thanks for looking.. Tom
PostSubject: Re: 61 Impala    Sat 07 Jun 2014, 12:37 am
PostSubject: Re: 61 Impala    Sat 07 Jun 2014, 1:27 am
That's looking nice !
Like the engine detailing!
PostSubject: Re: 61 Impala    Sat 07 Jun 2014, 2:13 am
  I'm not a real big bow tie fan but this is looking great all the way around, great work
PostSubject: Re: 61 Impala    Sat 07 Jun 2014, 2:40 am
Fantastic work!!
PostSubject: Re: 61 Impala    Mon 09 Jun 2014, 11:01 pm
This is looking sharp all round- the interior colours really work too.
Keep the updates coming, Tom.
PostSubject: Re: 61 Impala    Tue 10 Jun 2014, 2:41 am
Nice work!
I am not getting the last three pics.
60s era
PostSubject: Re: 61 Impala    Tue 10 Jun 2014, 6:07 pm
Thanks to All..
Sam : Try clicking on the Camera / Photobucket at the bottom of the square that says sorry.. That should take you to the PB page and clink again, it should bring up the pic's..
Don 't know why it showed the URL and not the picture , as it has done before..
Still learning to maneuver this sight..
Tom
60s era
PostSubject: Re: 61 Impala    Tue 24 Jun 2014, 9:55 pm
A little update on the Engine Compartment..
Tom[img][/img]
PostSubject: Re: 61 Impala    Tue 24 Jun 2014, 10:56 pm
That's a great looking engine compartment Tom.
How did you do the 'combined' wiring harness on the drivers side wheel arch?
PostSubject: Re: 61 Impala    Tue 24 Jun 2014, 11:14 pm
PostSubject: Re: 61 Impala    Wed 25 Jun 2014, 12:28 am
Looking good. The wiring harness is a good touch. it adds a lot.
60s era
PostSubject: Re: 61 Impala    Wed 25 Jun 2014, 1:01 am
Zbuckster -Geezerman - Skid..
Thank You all for the comments...
Skid : The Harness you asked about was made from assorted wires I had laying around..1st -- I stripped a wire that I thought looked good ( size wise ) then I found some real small wire between 26 -30 ga. Not sure of wire size but used the smallest I had . Then I inserted them inside the first wire..
The smallest wire is also what I used for the Generator wire's that go into the harness..just painted them colors I wanted..
Next : I used gap filling CA to attach Gen wires to encased wire and let dry then painted and
WA - LA wiring harness on fender well . The little clamps , on harness , are again the real small
wires left natural color..
Hope that helps .. Tom
PostSubject: Re: 61 Impala    Wed 25 Jun 2014, 2:13 pm
Great detailing under the hood, Tom. Wiring and plumbing all first rate.
61 Impala
» Old Motor Week Jon Moss T56 Impala SS road test video
» WTF!!! Why are Impala SS parts so damn expensive!?!?!
» F/S 94 Impala SS
» Powdercoat Impala SS wheels?
» Camaro gauge for caprice/impala mod
