  Community Build #4 60's-70's era drag subject
Go to page : Previous  1, 2, 3, 4, 5, 6 ... 9, 10, 11  Next
PostSubject: Re: Community Build #4 60's-70's era drag subject   Wed 21 May 2014, 10:35 pm
PostSubject: Re: Community Build #4 60's-70's era drag subject   Thu 22 May 2014, 2:44 am
Engine looks great, Snake !!
PostSubject: Re: Community Build #4 60's-70's era drag subject   Thu 22 May 2014, 5:59 pm
Correct firing order? .... err .... i did try with an online diagram ... i'm not changing them now even if it does run rough though lol
wiring and plumbing tasks from today ... started the cage too
PostSubject: Re: Community Build #4 60's-70's era drag subject   Fri 23 May 2014, 12:15 am
Some great plumbing and wiring!
PostSubject: Re: Community Build #4 60's-70's era drag subject   Fri 23 May 2014, 3:35 am
Great work on the Ferrari engine, it takes up most of the wheelbase. We need more V-12 hot rods. The web has a foto of a dragster with an injected Jaguar V-12, so cool!
PostSubject: Re: Community Build #4 60's-70's era drag subject   Fri 23 May 2014, 4:38 am
PostSubject: Re: Community Build #4 60's-70's era drag subject   Fri 23 May 2014, 10:17 am
The plumbing and wiring is looking great Colin.
An observation and a suggestion if I may.
Observation: The water hoses to the rad look a tad too thin but not overly so if you don't have anything a little thicker.
Suggestion: Try pushing the HT leads closer together and in the directions show in the photos. I think they'll look more realistic if you do.
On a real deal Ferrari engine, they go through and emerge out of a 'collector' tube but trying to replicate that is extremely difficult. I know, I have tried and failed!! LOL
PostSubject: Re: Community Build #4 60's-70's era drag subject   Fri 23 May 2014, 11:39 am
Thanks for the info Al, I've seen the collector type assembly and it looked a right royal pain in the backside to replicate so I thought I'd space the leads out and try and make a clamp/bracket type thing which seems to be just as much of a task.
Maybe just reposition them as per your input.... might actually be better.
The rad hoses didn't look too bad to the eye..... But now you point it out on the photo they do look a bit pathetic if I'm honest, I'll up the diameter a bit.
Any other ideas and tips..... Post away please chaps.
PostSubject: Re: Community Build #4 60's-70's era drag subject   Fri 23 May 2014, 3:05 pm
Great work going on in that chassis, Colin. Excellent job.
PostSubject: Re: Community Build #4 60's-70's era drag subject   Fri 23 May 2014, 4:28 pm
I have one, can I take it out for a test run...
PostSubject: Re: Community Build #4 60's-70's era drag subject   Sun 25 May 2014, 11:20 pm
I finally got a little time to work on this build, got most of the eng. done
got the firewall, tranny, drive shaft, clutch linkage and shifter linkage done
and the front axle moved back and on the frame
got a lot more to do yet. Got one more computer to do ( I think ) and then I can start working on this a lot more
Every body is doing great on their builds with good progress.
Old Coyote
PostSubject: Re: Community Build #4 60's-70's era drag subject   Mon 26 May 2014, 1:41 am
..... was able to get a little painting done this weekend ............. body panels for the Rattler are now in bright orange .....
.... also got some more work done on the chassis ........... chute and chute release, steering crossmember and steering shaft & wheel, throttle pedal, and fire extinguisher
..... test fit with a couple of the painted body panels ............
PostSubject: Re: Community Build #4 60's-70's era drag subject   Mon 26 May 2014, 2:51 am
Wow!! It looks great. The colors all really work well together.
PostSubject: Re: Community Build #4 60's-70's era drag subject   Mon 26 May 2014, 11:08 am
Lookin sweet !!
PostSubject: Re: Community Build #4 60's-70's era drag subject   Mon 26 May 2014, 11:18 am
Nothing wrong with orange, black and chrome when they all sit on the same vehicle.
Nice detailing on this too.
PostSubject: Re: Community Build #4 60's-70's era drag subject   Mon 26 May 2014, 2:11 pm
Ive been held back in production with checking rules, regs and images to make sure this stays within the guidelines for entries into its class.
I like to push boundaries for things and come up with "one-offs" whilst staying within the confines of the original.
decided to go with this sort of cage design, bit unusual but does the job. Got the loose wiring done, thickened the rad pipes up, added steering shaft, gear lever and pedals as close to regs as the scale would let me.
also saw this ... a swivel bar to allow easier access for the driver, need to try and find some more images online to see what ways they were locked in place
still lots to do
PostSubject: Re: Community Build #4 60's-70's era drag subject   Mon 26 May 2014, 3:29 pm
The HT leads look much better now Colin as do the water hoses.
Nice touch on the swivel bar. Methinks the driver needs it, as it looks like a real tight fit in there.
Good work on the cage.
PostSubject: Re: Community Build #4 60's-70's era drag subject   Mon 26 May 2014, 3:55 pm
Cage looks more like a sprint car cage than a drag cage, but it works and works well.
Old Coyote
PostSubject: Re: Community Build #4 60's-70's era drag subject   Mon 26 May 2014, 4:14 pm
Great work Snake ............ I'm sure that car would have really messed with the NHRA's collective minds back in the day
Great work !!
The funny car is really looking good Mike ......... beautiful work
Old Coyote
PostSubject: Re: Community Build #4 60's-70's era drag subject   Mon 26 May 2014, 4:24 pm
Got most of the body panels attached ............... decals have to come next ................ treated the SLIXX sheet with decal bonder this morning and will let it dry for at least 12 hours ............... also ordered a second decal sheet from Slixx this morning ( just in case )
.... last of the engine hoses are installed ............ after decals it will be on to finish the steering, front suspension, headers, and add the front canard wing ............ heading into the home stretch
PostSubject: Re: Community Build #4 60's-70's era drag subject   Mon 26 May 2014, 4:35 pm
Now that does look good!!.... Even without any decals
Thanks for the comments on my attempt too chaps
PostSubject: Re: Community Build #4 60's-70's era drag subject   Mon 26 May 2014, 7:58 pm
They are winding up nicely! Thanx for all the time put in and great fotos!
Old Coyote
PostSubject: Re: Community Build #4 60's-70's era drag subject   Wed 28 May 2014, 2:12 pm
.... Finished up my attempt at creating the Howard Cams Rattler from a Revell California Charger kit ............ took these quick shots out on the deck this morning ............ will try to get some better photos to go in the "Finished" thread .............. the build is really pretty much box stock, using only Competition Resins body panels and chute, a scratchbuilt injector scoop, and Slixx decals .............. everything in the chassis came from the box
PostSubject: Re: Community Build #4 60's-70's era drag subject   Wed 28 May 2014, 3:49 pm
beautiful job, nicely done.
PostSubject: Re: Community Build #4 60's-70's era drag subject   Wed 28 May 2014, 4:09 pm
Looks great John    Those 1/16th scale are better to detail and come with the tubing in the T/F and F/C kits, you did a great job as usual
Page 5 of 11Go to page : Previous  1, 2, 3, 4, 5, 6 ... 9, 10, 11  Next
» Community Build #4 60's-70's era drag subject
