 Ducati 900 NCR.
stevegt738
PostSubject: Ducati 900 NCR.   Thu 24 Oct 2013, 4:31 am
While waiting for paint for other builds to arrive, I started yet another one.
I first built this kit when it was first released back in the day, along with the 900SS & the Hailwood replica. Last year I bought all 3 reissues to do them again, and not as glue bombs this time.
Modified the rear engine mounts to make fitting to the fully assembled frame easier. Frame is meant to be assembled around the engine.
Filled in holes on the frame that are for the road gear on the 900 SS / Hailwood replica. Also removed the centre stand mounts and a few unused brackets.
Reinforced the seam on the tank/seat unit
Completed frame ready for primer.
First lot of priming
Work on the exhaust & paddock stand started.
Next step will be to prime the body work and frame with white primer ready for the TS8 Italian red.
PostSubject: Re: Ducati 900 NCR.   Thu 24 Oct 2013, 11:12 am
I built this one a couple of years ago.
Nice start.
PostSubject: Re: Ducati 900 NCR.   Thu 24 Oct 2013, 12:17 pm
These bike kits sure have some nice looking parts.
Looking good.
PostSubject: Re: Ducati 900 NCR.   Thu 24 Oct 2013, 5:24 pm
Excellent start.
stevegt738
PostSubject: Re: Ducati 900 NCR.   Sat 09 Nov 2013, 11:14 pm
Been some progress over the last week.
Coat of white primer laid down.
The race bikes don't have an electric start, so that had to go.
Nicked the left crank case cover from one of the Hailwood kits, looks better.
As some of the endurance racers kept the kick starter as a back up, I had to add the shaft and housing.  They slip the kick lever onto the shaft when needed and remove it when the bike is running.
Note the angle of the front carb, should be on a verticle plane. If you rotate the manifold to align the carb correctly, then the carb sticks out to far and sits to close to the frame tube.
A bit of surgery.
The manifold can now located correctly on the head, and the carb fits a lot closer to the engine.
The chrome is a bit dodgy. One side.
The other side.
Not good. All three Ducati kits are the same.
PostSubject: Re: Ducati 900 NCR.   Sat 09 Nov 2013, 11:18 pm
Nice work Steve. Sounds like you have made a few corrections I wasn't aware of!!! 001
PostSubject: Re: Ducati 900 NCR.   Sun 10 Nov 2013, 11:47 am
I wouldn't have been aware of the difference, but nice job on the corrections. !
PostSubject: Re: Ducati 900 NCR.   Sun 10 Nov 2013, 6:04 pm
Nice work.
stevegt738
PostSubject: Re: Ducati 900 NCR.   Sun 10 Nov 2013, 8:39 pm
Thanks guys. Re the mods, 35 years of riding road bikes (never had a car licence) and being my own mechanic, some things stand out like dogs whatsits as not quite right.
PostSubject: Re: Ducati 900 NCR.   Mon 11 Nov 2013, 4:12 pm
Looking good!
PostSubject: Re: Ducati 900 NCR.   Mon 11 Nov 2013, 6:34 pm
I have always loved the older Ducati's, I always remember when I was working in a garage a chap always used to ride past on a Black and Gold 900SS, you could hear it for ages both before and after he had gone past...
You have made a great start, I hope you don't mind if I tag along and watch Sir...
Ducati 900 NCR.
» Tamiya Ducati 916
» Ducati MHR
» Tamiya Ducati 916
» Ducati 900SS, Tamiya 1/12
» Ducati 916 - first bike
