 '49 Miss Majestic
Gothic Kustomz
PostSubject: '49 Miss Majestic   Mon 26 Aug 2013, 6:52 pm
Well here we go, this is another full on Kustom, 1949 revell Merc, so stay tuned,
Nothing but the cry'n now:
The new grill, time to fit and shape, then to the rear:
PostSubject: Re: '49 Miss Majestic   Mon 26 Aug 2013, 7:09 pm
001
Gothic Kustomz
PostSubject: Re: '49 Miss Majestic   Tue 27 Aug 2013, 10:35 am
Whew, here we are going a lil ol'scool, I'm now shaping, and forming, OH! but not like you think, no this is not a new form of putty, this is all plastic,and a lil bit of pro wield   kinda neat huh? :
As you can see, really rough stuff:
But here you can see it starting to take a lil shape:
After just a lil work:
PostSubject: Re: '49 Miss Majestic   Tue 27 Aug 2013, 11:47 am
Just looking at it I was amazed how smooth and without sanding lines it is. The fact it isn't some soft form of putty... but actual plastic, makes sense. My guess is that it's also strong, important where a joint may crack from sanding too hard. If you haven't done a tutorial yet, it might be a neat trick to teach.
I'm puzzled that the "pro-weld: doesn't soften and distort the spots where the goop is applied. When I built I learned the hard way that even a bit of extra glue could soften the other side of plastic causing a dimple. We had to use glue sparingly. Thanx for your new technique!
PostSubject: Re: '49 Miss Majestic   Tue 27 Aug 2013, 12:43 pm
After that title, I was half expecting a hydroplane show up !
I never cry while hacking plastic :o)
Looking forward to the build.
PostSubject: Re: '49 Miss Majestic   Tue 27 Aug 2013, 4:42 pm
I learned that trick from Bob Paeth and still use it. I buy straight MEK at Ace Hardware less than 12 bucks a quart I use it to make putty and build. Great stuff. I know a couple guys that make their putty with Testor's Liquid Cement. This is going to be a fine looking Merc.
PostSubject: Re: '49 Miss Majestic   Tue 27 Aug 2013, 6:05 pm
Looking good!
Gothic Kustomz
PostSubject: Re: '49 Miss Majestic   Tue 27 Aug 2013, 7:18 pm
I should do one, it's an easy trick, you can also use the orange testors tube glue, but it takes a while to set up (cure),just put a dab on a piece of plastic, and add powder'd plastic, mix real good and apply, let set, sand, takes a lil longer, but works the same, as it will melt the powder, therby making a bondo like gell,
It does dimple, but it dimples the plastic, I add the shaved plastic, then dip the Pro Wield to the pile, it would go easyer if I powdered the shaved plastic, I just find this way to be a lil more, hmmmm, workable?,
I learned this trick as a kid building, when all I used was tube glue, it kept melting the plastic, right to much glue in one spot, well to fill the sink hole,I created, I would add plastic, then glue it in the sink, then started using less glue, and more plastic,found I could use this as a filler, and made the 2 joining ends stronger.
Gothic Kustomz
PostSubject: Re: '49 Miss Majestic   Thu 29 Aug 2013, 3:08 am
OK, remember the other day of those shots I took of the stuff looking like brick morter, lol, well here is a shot of it with a lil work, I will take a few more before primer, but this is what makes building kustomz, the best, not only do ya get to to do kewl work, but you get to see it come to shape:
PostSubject: Re: '49 Miss Majestic   Thu 29 Aug 2013, 3:55 am
getting there one coat at a time.
001
Gothic Kustomz
PostSubject: Re: '49 Miss Majestic   Tue 03 Sep 2013, 12:37 am
Getting ready, with a lil prep work, for the new Kustom tail light's
Gothic Kustomz
PostSubject: Re: '49 Miss Majestic   Wed 04 Sep 2013, 11:13 pm
The start of a Carson style roof, maybe?
PostSubject: Re: '49 Miss Majestic   Thu 05 Sep 2013, 12:41 am
001
PostSubject: Re: '49 Miss Majestic   Thu 05 Sep 2013, 5:23 pm
Very cool stuff so far. Keep it coming!
Gothic Kustomz
PostSubject: Re: '49 Miss Majestic   Fri 06 Sep 2013, 1:02 am
Looks as if it worked just perfect, to me, now on to the sides, lose the drip rail, finish the kustom tail lights, and find something to cover the top.
PostSubject: Re: '49 Miss Majestic   Fri 06 Sep 2013, 2:07 am
I like the rear window treatment !
Gothic Kustomz
PostSubject: Re: '49 Miss Majestic   Fri 06 Sep 2013, 3:42 am
OK, the pass, side roughed in, now on to the driver side, need to do something with the upper right pass door corner, might just round it out:
PostSubject: Re: '49 Miss Majestic   Fri 06 Sep 2013, 4:41 pm
Seeing it in primer will be cool. Looks good.
Codfather
PostSubject: Re: '49 Miss Majestic   Fri 06 Sep 2013, 8:18 pm
Looking really good to me. All the body mods compliment the overall shape nicely.
Gothic Kustomz
PostSubject: Re: '49 Miss Majestic   Sat 07 Sep 2013, 6:59 am
Still plenty to go, but just had to take a peek:
PostSubject: Re: '49 Miss Majestic   Sat 07 Sep 2013, 11:31 am
001
dadooronron
PostSubject: Re: '49 Miss Majestic   Sat 07 Sep 2013, 2:12 pm
Wahooo! Have you got a colour in mind?
PostSubject: Re: '49 Miss Majestic   Sat 07 Sep 2013, 10:00 pm
Very,very nice.001
Gothic Kustomz
PostSubject: Re: '49 Miss Majestic   Sun 08 Sep 2013, 1:22 am
I would like to go with something from the ara, but with like a deep crimson, and either a gray top, with white and gray tuck-n-roll, in velvet of course, lol, no not the top, or crimson metal flake, with some home made kandy, and all white interior, or all grey, as I don't have and white velvet, but I do kno it will be a crimson, maybe with a blue kandy metal flake, dusting, to kinda give a shimmer of purple, lot's of options,
PostSubject: Re: '49 Miss Majestic   Sun 08 Sep 2013, 2:41 am
Looks awesome in primer. Nice workmanship.
'49 Miss Majestic
» '49 Miss Majestic
» Majestic 149 schematic needed
» majestic gribsby grunow 50
» My 94 caprice sputters when i drive it. feels like a miss.
» Miss Valkyrie
