 Porsche 911 GT1
Go to page : Previous  1, 2
PostSubject: Re: Porsche 911 GT1   Sun 08 Sep 2013, 3:06 am
Back when I built, I made an "arbor" on which to mount tires for drill based sanding.  It did work on firmer tires.  Thanx for putting some of your skills on video as it really helps builders and inspires newer ones to greater efforts.  3 cheers!
PostSubject: Re: Porsche 911 GT1   Sun 08 Sep 2013, 10:17 am
Nice idea on the tyre 'scrubbing' Dan. I used to use something similar years ago but lost the 'arbour'
Could you show us your method of attatching the wheel to the cordless drill please?
Codfather
PostSubject: Re: Porsche 911 GT1   Sun 08 Sep 2013, 8:04 pm
There's not a lot to show really, Al. But I'll try to get some fresh pictures or a vid done when the drill's back tomorrow.
PostSubject: Re: Porsche 911 GT1   Mon 09 Sep 2013, 12:39 am
001
PostSubject: Re: Porsche 911 GT1   Mon 09 Sep 2013, 6:36 am
Codfather wrote:
Thanks, Al. But, who's John?
The guy who had a "few" hits co written with a bloke called Paul? Seriously, top stuff, Dan. The decals would have been toast with me!
PostSubject: Re: Porsche 911 GT1   Mon 09 Sep 2013, 5:49 pm
Nothing wrong with those belts.
Codfather
PostSubject: Re: Porsche 911 GT1   Thu 12 Sep 2013, 5:16 pm
Thanks folks, the weather has been dismal recently, inhibiting body spraying, but with a break in the weather this afternoon, I broke out the Halfords Nissan White for another shot. There's a small chance of some progress shots this evening.
And Al, due to the work on our Leyland Roadrunner, the drill is otherwise located for the present time in a prior and more important engagement. There's not a lot to show really, the chuck of the drill has quite a long, fine nose, so reaches into the wheel easily and as the Porsche BBS wheels have long spindles inside them, it's just a case of securing the spindles in the chuck without over tightening them.
PostSubject: Re: Porsche 911 GT1   Fri 13 Sep 2013, 3:03 am
When I did the wheel sanding with a drill I just had a long thin fine thread bolt assorted metal washers of different sizes and with trial and error got each tire centered and tight, then went at it with sandpaper. A variable speed drill, or a regular one connected thru a rheostat to keep RPMs down worked. Nowdays, the rechargeable drills have pretty slow speeds, often 2 speeds, and that could do well also.
Porsche 911 GT1
» 1964 Porsche 904
» Porsche Carrera 6
» porsche 911 GT2 (tamiya - 1:24)
» Tamiya 1/24 Porsche 911 turbo 1989 - WIP
» porsche 911 GT3 (tamiya - 1:24)
